WelL done STEVE!! So i'm not the only one who believes in the .82 ex. housing. To me it is almost perfect for the rb25. all u need now is some cams and dial her in and u be smiling until the top half of your head falls of.
The guy who posted this originally has the GT30-40 intended for an RB20, so the 0.87 A/R would be crap.
Joel,
I was thinking about a better wastegate actuator as well. I don't really have a major problem anymore, holds 17psi well with the BOV mod I did.
I still don't quite understand how a harder spring would make a difference, although I haven't really thought about it either. Thing is, I want 8psi for around town and if the spring is set at "14psi" then I assume it will remain shut until that boost is reached? No good.
I dont intend runnign more than 17psi (1.2bar) anyway so I might be fine with the current setup, woudl rather spend on cams and nice exhaust manifold.
  • Replies 174
Freebaggin,
It also would come down to the EBC. Mine would do what ever boost I pumped in to it but I would notice some where around 500rpm boost would drop .5psi then creep back up to the dialed in boost. It strugged but would do it.
I have heard some good and bad things about the HKS EBC. Origionally I was going to buy one then at the last minute lost my deposit and bought a Blitz.
The older HKS EBC's are crappy, apparently the newer ones hold boost a bit better.
yep thats it.. I personally don't mind high boost all the time as with the RB20 if you drive normally the most boost it will make is around 5psi. BUT It is a bit of a pain in the arse when you try to take off a little quick in first and first gear snapps 1bar hard causing wheel chirp and makes you look like your thrashing it.
Got cams, dont think they, well exh, is dialled in too well as yet. I think a 0.87 may be a bit big for an RB20 too, but then again, I think a 3040 may be a bit big for an RB20 - depends on what you want though - Two different people can take the same car for a spin, one love it the other hate it.
Freebaggin, just stick with 1.2bar all day every day, it would make life more interesting:) You know you want to:p
Not sure if this info will help but i had a garret gt30 with a .7 front cover and .82 rear housing on a rb25. With 1.8bar i made 320rwkw. full boost was between 4-4500rpm. It was a very smooth power band. Power would start to drop off @ 7200rpm. It went to as low as 290rwkw @ 7600rpm with my old engine and set up.
I will defenetally post the resault... Mymechanic said : dont forget that u got stock internalls so dont exept big powrer , and i asked him how much u rekon? he said maybe 300 rwhp..
hes ganna set the boos to 16 to 18 psi and i think that would be enough for me for now till i get my internalls done or i swap the engine to RB25-26 and then i can talk about big power.. hehehe
So stay Tune...
Cheeres
--- Babak ---
Im with benm, i wouldnt go changing the internals of an RB20DET at that power level. Even though it is essentially a 100% increase over a std RB20DET, you are essentially increasing the effeciency of the engine with most of the mods (IC, filter, Exhaust) with only the turbo boost pressure increasing the stress on the engine.
There is evidence that boost doesnt actually hurt a turbo engine as much as revs as long as the tune is up to scratch.
Intersting to see your results...
Whoops - well I just got an HKS 3040 (1.12 AR exhaust ) & HKS high mount manifold - it may be a bit big for my RB25DET - but cause my internals are done, headwork, cams, cam gears and higher redline - I'm hoping it will be OK..... we'll see I guess...
So stay Tune...
Cheeres
--- Babak ---
What injectors did you end up running with this setup? I can't wait to hear about your results!
B-Man, that's gonna be fantastic mate, like you say, you've got the support gear to go with it and you'll be able to rev the tits off it to make use of the power band shift to the higher RPM.
Interesting the difference between the Garrett and HKS GT3040 CHRAs:
Garrett
Comp, trim = 56, 60mm/82mm
Turbine, trim = 84, 60mm, 55mm
HKS
Comp, trim = 50, 58mm/82mm
Minor differences in sizes. With that 1.12 housing it will be huge power!
RBSileighty - ATM i got the standard 272cc injectors, my mech. said that hes ganna power run it first to see if i need the injectors if so ill upgrade them to 600cc ones.
I cant wait myself either to see the resault.. im ganna go and have a look at the car tomorrow to see how far he went. his 1 of the best mechanics around.
Cheers guys
--- Babak ---
one more thing i was ganna say was, i dont think if im ganna do my internals, why? coz dont forget that it still is a RB20, so may be next step for me would be RB25 or 26 + forgies + my turbo setup = low 11s.
How does that sound? its true that the turbo might be a bit small but by then ill think about it... may be a big ass T51R SPL $$$ or TRUST TD06 or 7.. GOD knows better :D
Any ways.. Stay tune.
--- Babak ---
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
