  • Replies 64
jq11 goldcoast - tokyo
jq26 tokyo-cairns
jq967 cairns - goldcoast
These flights worked out the cheapest way to go, few hr stopover in cairns, but meh, will be good to adapt to the humidity again! got Big Day out a few days later. So i thought might be good to just suck it up.
You will see the sau-sa/vic group there they will all have there Red hoody's on come up and say hi.
I am heading over with the SA Section of this group. The group is wearing hoodies that look like
well i arrived ok and what an awesome place, just come back from the fish markets :)
bring on autosalon :)
Tsukiji fish markets?? If so then yes it is awesome, how good are the free samples. :D
actually i wasen't charging him
i was going to give them to him,
on another note guys
for anyone who is there check out the Dry carbon doors on the Top secret stand weighing 4.2 kg
No problems, nice thought..
Just know where he lives in relation to Tokyo and trying to find another gaijin at Auto Salon, well you know for yourself, the place is full of them.
And yeah the carbon on the Top Secret 35 is very nice. Got to go through their car a few weeks ago.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
