Hey Guys,
I have a Greddy turbo timer hooked up, it works well except that everytime I turn the car off and turn on again I have to set the turbo timer again.
Anyone know how to keep a permanent setting if its possible??
Cheers
https://www.sau.com.au/forums/topic/322208-greddy-turbo-timer/
Hey Guys,
Cheers
Hey mate, this would be because who ever has set the turbo timer up has wired both power wires to the ignition source. To fix it you need to find out which one is the power and which one is the ignition. The power one should be wired to a constant power source, eg power to your ignition barrel. And the ignition power should only be on when the ignition is switched. Would be simple to fix with a multimeter.
Let me know if this helps or you want me to explain it better :blink: (I can't explain stuff too good lol)
Matt
Let me know if this helps or you want me to explain it better :) (I can't explain stuff too good lol)
Matt
Cheers mate, I did download the manual though so I might try n see If i can just program it cos theres nothing programmed i dont think. if not...itll be off to the shop lol.
Sweet, but you shouldn't need a shop if you got some idea on wiring or how to use a multimeter and soldering iron/crimps. Pretty much the same as installing a head deck in your car, just gotta find the right power sources
good luck mate
good luck mate
yeh i 'shouldnt' need a shop lol but i dont know much about auto elec..gonna start learning about it all though.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
