  • Replies 260
For ppl that might be interested in a pre xmas or new year meet, let chuckie know. :thumbsup:
My suggestion is churchman brook dam. Nice roads and bbq facilities. Even seen a few evo clubs out there.
Churchman Brook dam
Good drive, I'm in pending dates.. things get pretty hectic in the silly season :/
:stupid::w00t: how do i get told ,Fu-k the walk up there ,weekend`s it`s PACKED OUT Jason,you need to go up lateish if your hoping to get spot as it`s full till abut 3 pm ,or you need to pop passed & have a look dude,
+1 on dont fkn bother on a weekend. Wungong dam is a bit more spread out, and has better carparks. :thumbsup: Plus, if you have a meet point in Kalamunda, I can show youse all my favourite drive through the top of the scarp. Only problem is, the longest straight is only about 200m, so the chances of all your lumbering lolvo's keeping up with the sheer might of Teh Fury is pretty low.
:P
*edit - :3some:
Is that a challenge? :banana:
just dont ask him to pull his shaft. some ppl get really weird about that on here. lolz
I see what you did there :P
Anyways, let's throw some dates around so we can all gauge interest and work out a day that most of us can make it!
A lazy Sunday towards the end of the month/early feb is my suggestion :)
two weeks ppl. bbq dont know where yet nth or sth. :cheers:
possible list, pretty sure we have all color stags covered:
mitsterbrau
chuckie
bubba
horrace
appealing?
d1_drifter?
Big Jim?
Odddyman?
blizzerd?
darq?
260rsstagea?
RS444?
ssshonky?
unique1?
.....and of course dale ( leave teh fury @ home for the mrs and get a lift in a real car.) lol
Edited by dirtyRS4
WOOOOOoooooow... It's been so long since i have been on here... And Chucky, you will be happy to know that i have decided to keep the Staj after that convo we had when you dropped off the intercooler ;)
I WOULD BE SO UP FOR THIS! So long as you don't mind me bringing my half beaten up Staj (Due to some ass clown hitting me and pushing me around with a bull bar).
I'll also bring the camera if any of you want shot's?
I'll make time for this! I believe that you are all thinking the 16th now? Glad i logged on now then!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
