  • Replies 47
hey luke!
do you by chance have the squishy rubber hose that goes from the front turbo inlet elbow to the air flow meter/airbox? - think i can see it in the box in that pic you posted up
also wondering if you have the following hose?
http://www.skylinesaustralia.com/forums/post-a286350-
"14463MG" in the image.
oh, and a stock rear turbo oil drain? ;) AHEM.
If it's in the box Nigel ur welcome to it. Best to come down and have a look. I'm going all alloy piping so getting rid of all the rubber stuff I've got.
Luke
Whole list of parts for sale from my 1999 R34 N/A GT-four sedan.
Front seats $200 pair with rails
Rear seats $150
All seat belts $200
Parcel shelf with 4 tweeter holes cut out $50
Roof lining in black velour $150
All pillars in black velour $60
Fuel tank $250
Front bar $200
Front guards $ 200
Bonnet (couple of stone chips/pin dents $250
Bonnet latch $50
Bonnet hinges $50
Cusco Master cylinder stopper $80
Glove box $50
Kick panels $80
Door Trims $100
Cusco Full bolt in cage $1200
Brake master cylinder $120
R34 GT-four gear box, Small crunch 3-4. Chuck some redline in and she'll be right, Complete manual conversion $1200 Will include clutch master, pedal etc
Clutch pedal $120
Clutch master $80
Brake pedal $50
Accelerator pedal $50
R34 N/A brakes complete set, discs, calipers, lines $300
R34 N/A air box $50
All Air con stuff $200
Brake lines $50
Heater box (non leaking) $150
ABS module $150
Climate control display $150
Bnr34 brembo's low k's, slotted rotors, A1RM pads, braided lines, complete set $2800
R34 Rear hubs, handbrake set-up, handbrake lever, lca, $300
If your after a stock part that isnt there let me know.
Will be adding more as i think of it.
Cheers Luke
Hi there i'm after the hazard light switch for my r34 gtt sedan. Have u got it if yes for how much including postage to 3073.
Cheers :laugh:
hey mate your front bar standard?
sure is mate. It's got the factory fog light holes but the brackets were all rusted so took them out. Also got the little antenna in the front passenger area, but doesn't work anymore.
Also keeping the hazard thing as I may need it.
Edited by Luke_ENR34
  • 4 weeks later...
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
