Well the thought has crossed my mind a few times about selling my HR32 GTS skyline ...
Was just wondering what would be a good asking price for it ...
1992 HR32 GTS nissan skyline
250,000km genuine highway kilometers
Suspension : Pedders sports rider lowered suspension all round , nolathane bushes in the front end and a pedders rear swaybar and a japanese front strut brace
Engine : RB20DE (standard internals)
Gearbox :Re4R01A STAGE 2 shift kit from a series 2 R33 GTS-T , also has the R33 torque converter and flex plate fitted at the same time
Intake : Pod filter and adapter
Exhaust : Coby extractors , Catco 3" hiflow cat converter , 2.5" catback to a cannon muffler
Wheels : 17x 7 SSA wheels 215/45 R17 tyres
ICE : Sony mp3 headunit , basic clarion slipts in front 1x tweeter missing , 2x 12" pioneer subs in custom fiberglass install in boot (heaps of boot space) sansui amp
As for other parts I have for the car :
Replacement headlight and indicator cant remember which side
Full front and rear 5 stud hubs/knuckles and 4 piston fronts , 2 piston rears with crossdrilled and slotted rotors
4x Standard 16" R32 wheels (no tyres)
Full BN sports Blister widebody kit ($2500) ( front, rear, sides and front and rear guards massive kit (50mm wider on front 70mm wider on rear )
2 1/4 " Catback system with 2x large mufflers for rego purposes
Mechanically the car is in good order and will pass roadworthy inspection no worries and is currently registered
was just wondering a rough price to start with just for the car with its current mods
here is a good pic ...
https://www.sau.com.au/forums/topic/322702-estimate-on-price-for-my-r32/
Have a look at Redbook and other similar cars. It also depends how quickly you need to sell, my understanding is in Canberra you can sell for a bit more, but because of the small market sometimes you need to wait until someone is actually looking for that type of car.
On another note would you separate the 16's and how much for.
Unfortunately you may find that not many people are looking for non-turbo GTS Skyline's these days so their sell price is very low... Most people wouldnt pay more than $5,000 - $7,000 especially if it has done a lot of kms.
The best bet would be to try and sell to somone in VIC or NSW where they have the P-plate restrictions, they are selling for more than the Turbo ones in those states, but most people will only pay big $$ for a 5-speed.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
