hey guys and gals, bit bored at home so though id post this timeline of my cefiro and r31
ok so after the r32 re-furbish sorta went down the drain as u can see
after parting out the 32 i had about 10k to play with so i bought this
it had busted JIC coilovers, blitz catback and a pod filter, id planned to keep it stock with just some wheels and lower it, but after the coilovers gave in the mods started and this is what its come to
1988 cefiro
engine:
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
Hypergear front mount kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
JJR silicone radiator hoses
R33 GTS-t air box
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
custom metal intake pipe
Blitz sandwhich plate
JJR oil cooler kit
gutted cat
GReddy water temp sensor
RedTop RB20 rocker covers
battery relocated to boot
fuse box relocated under the dash
driveline:
5speed manual
Jap spec Excedy 3 puk ceramic clutch
Nismo 2way lsd
lightened C33 laurel flywheel
Redline shockproof gbox oil
brakes:
r32 twin piston front calipers
r32 front discs re drilled to 4stud
s15 rear hubs
stock rear discs re drilled to 5stud
BM44 brake booster
Cusco BMS
suspension:
Whiteline adjustable rear swaybar (27mm)
JJR front swaybar (30mm)
JJR solid steering shaft bush
TuneAgent castor arms
JIC camber arms
JIC FLT-FAS coilovers
JJR solid rear cradle bushes
JJR rear strut brace
Cusco front strut brace
JJR front under car brace
ISC rear toe arms
ISC rear traction arms
interior:
GReddy boost guage
Defi oil temp/pressure and water temp guages in DIN slot
JJR drift handbrake button
GReddy turbo timer
Bride drivers seat
Bride centre console
R32 passenger seat
Cusco C33 laurel rollcage
Nardi 350mm deepcorn
GKteck boss kit
rx8 gearknob
Factory Nissan floormats
Kenwood headunit
JBL front and rear speakers
train hang ring
deleted all a/c related parts
fire extinguisher
exterior:
Autech body kit
Nissan factory weathersheilds
late model "laurel style" chrome grill
roof spoiler
R34 GT-t rear windscreen wiper
GKteck bash plate
wheels and tyres:
front:
17x9.5 +5 SSR Professors with 215/40 Federal 595s
rear:
17x9.5 +22 SSR Professors with 235/40 Federal 595s
Rays wheel nuts
https://www.sau.com.au/forums/topic/322765-kriss-a31-cefiro-and-r31-4door/
then this happened, sandwhich plate wasnt on properly and dropped all the oil while i was running in the motor, f*ked the head and exhaust cam and thats pretty much where im at now, motor is out again and is getting the head fixed and ive got another hks cam from japan
It looks like it comes up a little higher than my manual console (yes, mine isa proper manaul console, not an auto turned manual console)...maybe I'm just tripping out? Mine is black, and its covered in all sort s of shit in a dark shed so it probably naturally looks smaller....
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
