If so get a cash settlement!! :) then www.halfcuts.com.au I think for a new door think I got mine for $150 delivered, and it was the right colour too! If not a panel shop should be able to paint it and blend the other door and rear quater for around $250 - $300
and you will still have money left for beir!!
Cheers Mick :)
I've ended up going through Lacey in Burwood.
Showed me around the workshop, booth's and current cars being worked on etc... very impressed.
I've been in a few other workshops in years gone by, this is the best setup I've seen.
Cheers Mick :banana:
no worries seams the stageas have not had much luck lately with panel damage..hope all goes well and you get it back soon
  • 1 month later...
Car all fixed, got it back last Friday.
They just needed it for 4/5 days.
Here's the after shots.
Bit dirty, got to give it wash.
B Lacey did and excellent job, color match is perfect, car is straight etc..
Very Professional.
I would recommend them to anybody.
if you don't mind me asking, what sort of money did it cost to get this repaired?
i dinged my driverside door, not as extensively as this but on the crease up by the door handle :O
just wondering how much its gonna cost me roughly
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
