Hardtuned.net Drift Attack 2010
~ Saturday 19th June 2010, Winton Raceway, Victoria ~
The biggest drift event in Victoria for 2010, $10,000 IN CASH & PRIZES UP FOR GRABS !
*Top 16 battle for street class*
*Top 16 battle for pro class*
*Team drift battle*
*Dr Drift Extreme Entry Comp*
*Wheeltech Drift Passenger rides*
*PROMO GIRLS*
*GIVEAWAYS*
*MC MOZZ*
PLUS:
*Luke Jacobs/Nathan Charles Sportsmanship Award*
Pro Class 1st Place - $4,000 CASH
Pro Class 2nd Place - $2,500 CASH
Pro Class 3rd Place - $1,250 CASH
Pro Class 4th Place - $750 CASH
Street Class 1st Place - $600 CASH + PRIZES
Street Class 2nd Place - $300 CASH + PRIZES
Street Class 3rd Place - $200 CASH + PRIZES
Street Class 4th Place - $100 CASH + PRIZES
Dr Drift Extreme Entry Comp Winner $500 CASH
Team Drift Award
This is a competition day, with an emphasis on qualifying and battles. The beginners section will be closed, this is not a standard practice day.
Spectator Fee:
$20
Wheeltech Drift Passenger Rides:
$40 for 3 laps
Driver Fee:
Pro Class - $290
Street Class - $190
Pre-Entry is compulsory at this event.
Entry forms and payment options can be found here: Vic Drift Website
Acceptable Licenses are: AASA or CAMS L2NS - No license means no going on the track!
On the day purchase of AASA license:
AASA license $50
(Can be purchased at the Winton office on the morning of the drift day. Entries will not be accepted without proof of license or receipt of payment from Winton)
Please note : VDC board members will be checking AASA and CAMS licenses, this year we will be checking everyone. Please ensure all your licenses and memberships cards are valid.
The usual requirements as always are:
*Long sleeve and long pants of non flammable materials i.e. No Nylon
*Closed footwear
*Helmet that complies to Australian Standards (has ASA or Snell Sticker)
*Car needs to be in a good condition, no oil leaks, no loose items in the car and battery secure. It must pass scrutineering to be allowed on the track!
*Working seat belt/s (give it a pull and make sure it locks)
* Every car must have the correct amount of wheel nuts:wheel studs. Get it right before you get to the track!
Basic Scrutineering Guide can be found here: Vic Drift Website - There will be NO EXCEPTIONS at this event!
* FIRE EXTINGUISHERS ARE COMPULSORY AND MUST BE FITTED CORRECTLY IN THE CAR AND WITHIN EASY REACH OF THE DRIVER!
Dont miss out, on what is shaping up to be one of the biggest drift events in Victoria !
Edited by pink180
shit hot, i'll be there with some mates.
lol at super lap one of my mates lost his shit mid-sentance (serious conversation with whiteline rep) when he saw the drifters come on track "blah blah bla-OH MY GOD, THEYRE DRIFTING!" hah ha he's never gonna live that one down.
Hi Guys,
This is going to be seriously Huge!
The Pro Class list is the closest thing to a D.A event this year for sure, with most of the Aussie big name drivers attending!
Ill update the list for you shortly so you can see.
And join the event on Facebook too!
http://www.facebook.com/group.php?gid=1054...101&index=1
Was a good day, some little things annoyed me though, never been to winton before so i didnt realise there was no seating, was there for 5 hours and there was no where to sit, the track is too far away from where you can stand (not much you can do about that i guess) and also the extreme entry comp, the guy on the PA was saying that was judged by the crowd, if so why was there an official near me telling other ppl on the cb that the scores were based on entry speed and clipping point and then after every run they were discussing the score for each?
Other than that is was a good day, will remember to take a seat with me next time i go.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
