That was the other day? but anyhow, HAPPY BIRTHDAY YOU CRAZY MAN!!
Hope the next year brings some excitement to you with the Rex...just keep it all in one piece and the license at the same time! :( Don't do anything i wouldn't do.. actually don't do anything what i would do!! lolz
p.s. now you're an old fart just like me :) j/k
happy hizzy mah nizzeh!!!
fo shizzal yo fizzal on yo huzzal!
*scratches head..
im trying to decode that..
and i think its "happy house my African American, for sure your *something* on your *something*"
am i close..??
hehe thanx guys, Im 24 now....getting old
Yer I went out on saturday night for my bday, got tanked at a mates in the city and then went to Dibiers(it was the only place that would let pissed c*nts like us in) got kicked out at about 2:30 and then went home....a good night all in all.....
happy belated birthday... din have internet for a week so was blissfully unaware of any SAU forum goings on...
Now if only I could find Terrance's address so I could give it to you as a birthday pressie... I'm sure you'll enjoy it. I'm sure it would be much fun... just like Tom n Jerry of the old days...
Funkey- Yes!!!! Id love that!!! me and inasnt could go and have a field day!!
Dj- none, my stomache felt horrible the next day and I wouldnt have been able to hold any souvos down
Horus did i tell you i paid terrances house a visit?? well i wouldnt call it a house, its old ass caravan in this seedy caravan park. His house was so bad it makes the trailerpark trash that you see on springer look like the Hilton hotel. :D
I felt dirty and just standing at the gates of the park.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
