dudes got my hands on this pump, but dont know wat is or out of.
try to attach pics, it has these numbers on it, can anyone identify them. my guess is its a gtr pump....maybe
A42-621B70
12V 8Y09
UNISIAJECS
I dont know how old it is so if u guyz had the choice wud u use this one or buy a new bosch. I have heard it running and it has noticeable whinning so i dont know if its signs of old age or normal for the pump. it looks ok but not sure .
i need to change my standard pump on my r32 gtst and was hoping to use this one.
thanx
jay
https://www.sau.com.au/forums/topic/32335-feul-pump-question/
All I can tell you is that from the looks of it, its a GTR/Z32 pump. the older ones have black rubber around them, but otherwise look identical. The diaphram at the top gives it away.
Some what stabbing in the dark now, but the R32GTR/Z32 ones have black rubber, the R33 ones dont, as per the photo you have up.
I must qualify and say that I have only ever seen about 8 or 10 of these before, so I am not 100% sure. It will probably make less noise when it is in the tank and has fuel to suck. Should be good for around 250rwkw.
  • 4 months later...
i found the pump is a r32 gtr pump. the gtr pump has a round 20cent size diaphram sitting on a angle at the top. gtst pumps dont have this at the top. also found out it was really noisy cauz the pump was cable tied directly on the bracket meaning metal on metal contact and the metal braket sits on the metal fuel tank hence the noise !
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
