Hey everyone,
just thought id share my quater mile time with everyone.
the car has 246 awkw.. just comp, pods, cat back exhaust, and booooost lol
i was very happy with the times..
and just to clear it up, the gtr i raced on the right lane was hella quicker but had to slow down at the end cause if he hit 11 sec again they were going to kick him out becuase he didnt have an ANDRA licence. so yeh he was quicker but was slowly pulling.
still found it a good race.
let me know what yous think !!
Edited by Chris_GTR26
https://www.sau.com.au/forums/topic/323451-raced-my-car-at-wsid-last-night/
my 60ft was 1.800
and i was running shitty old tyres on heavy 18 inch rims
i was launching it at 6,000 rpm...
and in the video the purple gtr looks like its heaps in front.. but he wasnt.
towards the end i was at his rear bar then he stopped.
was ur dyno done on rwd or awd. 240-250 awkw is huge for stock turbos, and pretty spot on for rwkw given roughly 10% difference between the two. Either way top effort, u might even touch 11s if u take off slightly quicker.
Edited by linkems
I saw ur car there looks good, I was in a White R32 GTR..
ahhh yeh yeh i saw you, thats a very clean r32 man looked nice.. i usually go up to some people with skylines and talk to em, but the line was going that quick lol. mine was very very dirty.. i didnt get a chance to wash it as of getting home late from work so yeh didnt look too good at all lol
i saw one you got, i think it was 13.6 .. is yours a stocker ??
it was awkw at croydon racing developments ... i hadnt driven the car for about 6 months and if u saw the car ( dirty ) you could tell lol.. but yeh i was breaking traction 1st and half through 2nd so a bit lost there.
i got the best time of a 12.210 that night so i think its capable of 12 flat with some practise and better tyres ;)
Yeah the line was going quick, lol.. yeah first run was 13.6 getting use to the new clutch, then ran a 12.8..
catback, pods n running 13psi..
thats really good mate, well this is good info for you man,
cause i ad cat back exhaust, pods, 14 psi and got 12.7 ..
just fitted the apexi power fc. got 30 awkw gain and dropped it down to 12.2
but i will admit.. the second time i took off more violently, as for th first i just rode it.
so yeh mate idk if that helps you
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
