100% agree with you. The car isn't worth much. It is just the demand on "P plate legal" Skylines (or any sporty car) that pushes the price up. :D
My advice for the OP - nothing wrong with the car - but paying the price of a turbo for a non-turbo car is un-fair on you IMHO. Dealerships and people in the know are ripping off P platers.
End of the day your money, each to their own etc....
I reckon it's best to buy it privately off another P-plater who are in a rush to sell their car to upgrade to turbo lol.
But the car might be thrashed.... But then again, what skyline hasn't been pushed before hehe
The price is high becuase of market demand.
Think about it - the criteria this car has.
- Coupe
- Manual
- Big brakes
- Skyline
- R34
- P-plate legal
Probably the ultimate n/a R34 setup straight of of the factory.
Easiest car to eventually turbo charge (if you decide to) - as it is a manual and has all the support mods needed for a turbo - such as big brakes.
^Exactly right, P-platers want skylines but due to the restrictions can't drive a turbo, forcing the prices of N/A's up and the turbos to drop, there aren't many decent N/A 34s around nowadays.
I've had my car off the road 8 months for a shop trying to get a N/A R34 turned into a turbo one by way of replacing.. apparently f**king everything and still maybe "not possible"
Epic.
So who knows, maybe I'll sell you mine for $5 and just wish you luck with it.
I'll be putting mine up for 14 this weekend and should sell quickly, even if you look at n/a 33s they are expensive and only a couple on there.
Some P plater will love my car and just fork out i think
Epic.
My bro got his r34 gt-v converted to turbo. Simple as n/a engine out. Turbo engine in. Hook up looms to the engine and ecu. Started first time.
Yea..... I just don't see how it can take 8 months and they reckon it might be "impossible" lol. Oh wells....
I think putting in a DEt engine is much easier than making a DE+t
Yes, it is easier, but you will still have some headaches in sourcing parts and there's always a chance that something will go wrong with the conversion?
So for the prices turbos are now, you might as well just sell the NA and buy a turbo :P
Took Femno 2 days to get it going lol. We dropped the car off and he already started ripping the engine out :P I guess making a de+t would be harder but still not that long unless the mechanic is useless
Took Femno 2 days to get it going lol. We dropped the car off and he already started ripping the engine out ;) I guess making a de+t would be harder but still not that long unless the mechanic is useless
Is he good with labour prices? :3some:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
