Just fitted whiteline adjustable swaybars front and rear to my car.. and I've got to say, bang for buck they are absolutely the BEST thing I have done to my car. It just feels so much tighter, so much more planted, and best of all has had very little effect on the ride quality of the car.
I would recommend doing them before adding big power mods to your car, it lets the sports car hidden behind soft springs and skinny swaybars shine through :P
Anyways I'm done ranting.. but if havent got swaybars you are missing out! ;)
https://www.sau.com.au/forums/topic/323675-swaybars-r33-gts25t/
+3 I installed a whiteline adjustable rear swaybar on my R34 GTT yesterday and OMG what a difference. Car feels so stable and can go around corners much faster without realising it. Absolutely fantastic! Cant wait till I get the front sway bar on as well!
Havent been able to fully test it out as the roads were wet all day yesterday. Even in the wet its soo much better.
Edited by Harey
Not sure mate, I have the adjustable ones from Whiteline (Which I think are the largest anyways). They have it set as hard as it goes on both sides and honestly to me it feels pretty good! Maybe on real rough corners it bounces a little too much but thats easily fixed by putting it on a lower setting.
Harey: Dont know about you but when powering out of a corner the back end just feels glued now, rather than that slightly dodgy leaning/twisting sensation I used to get. When you fit the front one you will definately notice it will feel a lot more responsive and resistant to understeer. :domokun:
Harey: Dont know about you but when powering out of a corner the back end just feels glued now, rather than that slightly dodgy leaning/twisting sensation I used to get. When you fit the front one you will definately notice it will feel a lot more responsive and resistant to understeer. :thumbsup:
Yup for sure. I find it hard to describe, summary it is VERY VERY GOOD! It also allows the car to take mid corner bumps while still keeping the car flat.
what size is generally best on the rear for r33 street use?
i have a 24mm adj. going on the front, but i dont want to fit it till i have one for the rear
Hey mate
A 20mm adj rear sway bar is plenty on a street going R33. You will regret going and bigger than that as you will be lifting the inside wheel and loosing traction which is OK for drifting I guess but basically crap for everything else.
Also no worries fitting a bigger front sway bar without doing the same on the rear it will be a massive improvement. In fact some guys go back to stock rear sway on the track for traction reasons listed above. Bigger is not always better with sway bars.
Chuck that front one on and enjoy! :P
Hey mate
Chuck that front one on and enjoy! :banana:
doesnt it kind of promote understeer though, with only the front one done?
It may - although IMO the skyline is a taily car to begin with. I will probably end up with my new swaybars on middle front and soft rear, will start soft/soft and go from there but if i was a gambling man that would be my bet :D
to everyone who has and recommends an adjustable one, have you actually played with the adjustments, or did you install it and adjust it to clear things and forget it?
I have to admit that I havent played with the settings, theyre both on hardest.. BUT I have king springs and standard shocks which are both fairly soft. In theory this keeps the car sitting flat while still being as grippy as a car with softer settings, and on my car I think I've hit a fairly good combination. My friend who drove it reckons it handles like a cat on carpet haha.
If you already have fully hektic coilovers/ you might be in a different position to me :D
i have 24mm front and 20mm back its plenty :(
you do not want to go too big
They are the regular whiteline sizes for r33
I have 27mm and 24mm, doesnt feel too big to me, and like I said, theyre adjustable so if its too firm back it off :P
I use selby adjustable 27mm front and 24mm rear. Currently running front on 2/4 stiffness on either side and rear on full soft. Handling balance is pretty neutral, very little understeer and controllable oversteer that tends to want to straighten up rather than get bigger. This is with 180rwkw running r compound tyres.
Had the rear bar on full hard before - might be good on the track however it made the rear end feel a bit to sketchy for my liking. Hard to describe the feeling but I guess it felt like there was the chance of turn in oversteer and you couldnt fully trust it. Might have been better if I had adjusted the front stiffer but I couldnt due to the stock links not reaching the hardest two holes so I backed off the rear bar instead.
Now running street tyres which are wider at the rear but have not had a chance to try them out enough to make a judgment.
i have the blade ajustible ones
24mm front BNF24Z
20mm rear BNR20Z
both are blade ajust set on medium front and rear feel amazing i think that they are perfect for a street car that goes to the track, i went drifting and the stability was so much better and far better than stock, i cant wait to get my coilovers in to see how much better it is after they are in!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
