Its all about power to weight with those karts Luke... ;)
yeah, micks just going to punch himself around the track. with his powerful guns. like a man. a real powerful man. he kiss's them at night. cause he's powerful gay.
time for more coffee
  • Replies 79
updated list...
1. Nathan R +1
2. Ross
3.Mick (bullet32)
4.Pat (randon_I_Am)
5.James (DriftGTS)
6.GTRKat + Pete (if on the 4th July)
7.Chris - CeJay
8.Luke (Frink)
9.Jazz
10.
at this stage we're going to be holding this on the 4th July
11th is good for me, better than the 4th actually. I has to work on the Saturday night (3rd) - stupid users wanting to use their system during the week...
Prefer it to not be a Saturday, will automatically rule Pete out as he has soccer.
***NEW DATE*** Sunday 11th July
1. Nathan R
2. Ross
3.Mick (bullet32)
4.Pat (randon_I_Am)
5.James (DriftGTS)
7.Chris - CeJay
8.Luke (Frink)
9.Jazz
10. Dave
11. CDM
12. Teon
13. Andrew P
14. MA70R
15. Dustin
16. Mark (Bluprint)
For those who want to consume alcohol at the lunch please remember to have someone else drive!
