hey guys just see what you guys think of this
my cousin has a r34 gt-t manual ( stock ) other then a pod filter and cat back
and one of my mates just bought one with a exaust, pod and been boosted to 10psi
but it was a auto and now converted to a manaul but its a shit load slower!!!! even though its running more boost..
how is this possibal are the auto's de tunned?
any feed back is good feed back
Yes it's me, and yes that R34 is slow haha.
I just can't wait till I get a turbo-back exhaust fitted and the engine/turbo should rev quicker and be much more responsive.
But yes, i would also like to know what other people think. Are the automatic R34 GT-T Skyline's de-tuned from factory just like the automatic S15 200sx/Silvia's are?
Cheers for any help :ninja:
De-tuned? No
The Auto has a different ratio diff to the manual, That would play a part. Also engine condition, service history, type of fuel being used, condition of fuel pump etc etc
but to play a big enough part that the one that had the conversion was running a singel stage boost controler and significantly slower?
Jace, I honestly reckon it is due to my car having the standard exhaust. Once I get the turbo-back exhaust, power fc, electronic boost controller and a tune i should be looking around the 270-280rwhp mark.
you wont get 270-280 with just those mods. The stock R34 turbo wont boost about 13psi with 14 maxing its efficiency range. I saw about 250rwhp with all those mods. I have a full turbo back apexi 80mm dump with 100mm exhaust.
Edited by ZXY
Hrrm.. Maybe you just got a 34 in bad condition or something wrong with it? Mines an auto converted to manual and its perfectly fine.. havent done heaps to it, pod, zorst from the turbo back, lightened flywheel an hd clutch.. Nothing special and its got a good boot to it running stock boost.
Have you had it serviced? does it do anything odd? ie: idle funny, backfire etc??
Hope you work out what it is mate, maybe its been boosted and not tuned so afr are rooted?
Good luck buddy hope you work out what it is.
Also - be warned that if you need to upgrade the clutch (like i just have) the japs usually convert with an r33 gearbox so you would need a different clutch to a 34 clutch (one is pulltype and the other is push type).
Could cause you some drama if you get the wrong one first because I've been told its not easy to determine until you drop the gearbox out.
-Steve
Edited by itsme
Nah nothing funny about it.
I need to service it (plugs, oil, filters, throttle body clea, etc) but nothing unusual.
I know i can get close to 280rwhp with the usual mods (Z32afm, boost controller, exhaust, intake, fmic, computer, tuned correctly), as my old skyline was making 265rwhp with those mods :)
Yeah it does backfire, only because I unbolted the cat from the rest of the exhaust and have been driving around like that (i got bored of a dead quiet exhaust and did this till i get my proper exhaust haha)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
