Body - R32 4 door white, Vertex bodykit, Black 17x9.5 +15 Driftek's, Federal 595RSR
Engine - Rb25det, high mounted s/s, Garrett GT3037s, Tial 38mm gate, Nismo 740cc, modified Freddy manifold, 80mm throttle, splitfire coils, fmic, greddy oil cooler and 40mm radiator.
Trans/diff - Rb25det gearbox, Nismo 2 way, hks super single clutch.
Suspension - Tein drift master coilovers, cusco rear camber arms and hicas lock bar, RG tension rods, front adj camber top control arms.
Interior - 4 door 6 point cage, R33 front seats (street), 2x Sabelt GT1 fixed back (track), 2x harness's, nardi steering wheel, remote mount bty to boot.
Electrics - Apexi PowerFC, Greddy profec b spec II, Greddy turbo timer, Pivot shift light, autometer boost guage.
Mine since Jan '10 and currently rebuilding from a stripped drift pig to street weapon.
Pics soon!!
https://www.sau.com.au/forums/topic/325415-my-r32-taxi/
  • Replies 50
Posted Images
Removed broken/munched speedo shaft and gear from gearbox, Only chipped a few teeth on 5th and reverse gears. :)
Also fitted up super quiet catback $50 to run under the radar and scored a set of non projector headlights $50 :(:(:(
https://www.sau.com.au/forums/topic/325415-my-r32-taxi/#findComment-5368103
nice , seems like a fairly low reading for a 3037? , usually they're good for around 400rwhp? would still be heaps of fun in such a light car!
Built for response and reliability, Numbers will come later!
VCT n/w (actuator clicks but no advance of cam), low boost (16 psi), not much timing and wheel spin on dyno!
Want to build a good fuel system for e85, wind the boost up, throw some timing in and correct the rear camber!
Edited by RED513
https://www.sau.com.au/forums/topic/325415-my-r32-taxi/#findComment-5370709
