  • 1 month later...
  • Replies 50
Posted Images
  • 9 months later...
Been a while,
clutch fixed, replaced a piston and head gasket, custom surge and breather tanks, 3x bosch fuel pumps ready for E85.
scored some series 2 taillights as well
Edited by RED513
  • 4 weeks later...
  • 3 weeks later...
pics? :rolleyes: Your 32 is really coming along nicely. Congrats on a really keen car mate
No pics as its messy atm
Trying to track it for some sprints but motor keeps smoken.
Bought a spare head last weekend, In getting full reco with mild port job,
Just undicided on bottom end??? 25, 26 or 30??? Do have spare 25 block which has been tapped/drilled/cleaned, ready for bore/forgies.
All comes down to money!
Edited by RED513
go the 30 :ph34r: , pics of your car all messy , i wanna see what you did with the 2d skirts
RB25 still has 160psi across all six, valve stem seals ??? (no smoke when boosted below 4k rpm)
Spare head being built, mild port job, full reco, gtr cams, solids and valves, no vtc. Will restrict oil supply, drill block and head oil returns whilst off, external return kit.
Just keeps going! lol
  • 1 month later...
  • 3 weeks later...
This is one tough 32 four door man. Love the GTR bonnet n grill combo on foru doors.
The '25 with the 3037S is tits! Nice man, love what your've done.
Keep up the good work!!!! :)
Thanks mate, step 1 RB30DET nearly ready just needs assembling
So far:
Rb25 head. light port, drillled, full reco, std cams, no vtc
RB30 Block, std bore, restricted, drilled and debured.
Crank collar, grub screw, linish and balance.
std pistons and rods, new rings,
new acl race main and rod bearings.
new N1 oil pump and waterpump.
genuine gasket set and cometic headgasket.
  • 3 weeks later...
RB30DET running :nyaanyaa:
Rb25 head. modified, drillled, full reco, no vtc, 20 inlet cam, 25 exhaust cam, dayco 94407 timing belt,
RB30 Block, std bore, restricted, 1xhigh/1x low tensioner, drilled and debured, genuine gasket set, 1.2mm cometic headgasket
RB30 Crank, collar, grub screw, linish, std pistons and rods, new acl race rings, main and rod bearings.
New N1 oil pump and waterpump, Greddy oil cooler and relocator, Greddy style manifold, 850cc, 2x 044 pumps, 1x 040 intank pump.
Still running GT3076 .63 with 38mm tial gate under manifold & same tune from rb25.
Going to move gate and plumback with new stainless dump then tune on E85.
Gold Coast 4 door <3 :D
We have 3x skyline 4 doors:
Mine, R34 4door and another R32 4 door, all highly modified
Pop in anytime:
FFF MOTORSPORTS
5/14 bailey crescent
Southport, 4215
Matt 0414 233 005
Edited by RED513
Pop in anytime:
FFF MOTORSPORTS
Southport, 4215
Matt 0414 233 005
Yeah nice!
Sounds good. should be on the road within the month ;)
i got a build thread in the build section.
have a good one.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
