  • 1 month later...
  • Replies 50
Posted Images
  • 9 months later...
Been a while,
clutch fixed, replaced a piston and head gasket, custom surge and breather tanks, 3x bosch fuel pumps ready for E85.
scored some series 2 taillights as well
Edited by RED513
  • 4 weeks later...
  • 3 weeks later...
pics? :rolleyes: Your 32 is really coming along nicely. Congrats on a really keen car mate
No pics as its messy atm
Trying to track it for some sprints but motor keeps smoken.
Bought a spare head last weekend, In getting full reco with mild port job,
Just undicided on bottom end??? 25, 26 or 30??? Do have spare 25 block which has been tapped/drilled/cleaned, ready for bore/forgies.
All comes down to money!
Edited by RED513
go the 30 :ph34r: , pics of your car all messy , i wanna see what you did with the 2d skirts
RB25 still has 160psi across all six, valve stem seals ??? (no smoke when boosted below 4k rpm)
Spare head being built, mild port job, full reco, gtr cams, solids and valves, no vtc. Will restrict oil supply, drill block and head oil returns whilst off, external return kit.
Just keeps going! lol
  • 1 month later...
  • 3 weeks later...
This is one tough 32 four door man. Love the GTR bonnet n grill combo on foru doors.
The '25 with the 3037S is tits! Nice man, love what your've done.
Keep up the good work!!!! :)
Thanks mate, step 1 RB30DET nearly ready just needs assembling
So far:
Rb25 head. light port, drillled, full reco, std cams, no vtc
RB30 Block, std bore, restricted, drilled and debured.
Crank collar, grub screw, linish and balance.
std pistons and rods, new rings,
new acl race main and rod bearings.
new N1 oil pump and waterpump.
genuine gasket set and cometic headgasket.
  • 3 weeks later...
RB30DET running :nyaanyaa:
Rb25 head. modified, drillled, full reco, no vtc, 20 inlet cam, 25 exhaust cam, dayco 94407 timing belt,
RB30 Block, std bore, restricted, 1xhigh/1x low tensioner, drilled and debured, genuine gasket set, 1.2mm cometic headgasket
RB30 Crank, collar, grub screw, linish, std pistons and rods, new acl race rings, main and rod bearings.
New N1 oil pump and waterpump, Greddy oil cooler and relocator, Greddy style manifold, 850cc, 2x 044 pumps, 1x 040 intank pump.
Still running GT3076 .63 with 38mm tial gate under manifold & same tune from rb25.
Going to move gate and plumback with new stainless dump then tune on E85.
Gold Coast 4 door <3 :D
We have 3x skyline 4 doors:
Mine, R34 4door and another R32 4 door, all highly modified
Pop in anytime:
FFF MOTORSPORTS
5/14 bailey crescent
Southport, 4215
Matt 0414 233 005
Edited by RED513
Pop in anytime:
FFF MOTORSPORTS
Southport, 4215
Matt 0414 233 005
Yeah nice!
Sounds good. should be on the road within the month ;)
i got a build thread in the build section.
have a good one.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
