  • 1 month later...
  • Replies 50
Posted Images
  • 9 months later...
Been a while,
clutch fixed, replaced a piston and head gasket, custom surge and breather tanks, 3x bosch fuel pumps ready for E85.
scored some series 2 taillights as well
Edited by RED513
  • 4 weeks later...
  • 3 weeks later...
pics? :rolleyes: Your 32 is really coming along nicely. Congrats on a really keen car mate
No pics as its messy atm
Trying to track it for some sprints but motor keeps smoken.
Bought a spare head last weekend, In getting full reco with mild port job,
Just undicided on bottom end??? 25, 26 or 30??? Do have spare 25 block which has been tapped/drilled/cleaned, ready for bore/forgies.
All comes down to money!
Edited by RED513
go the 30 :ph34r: , pics of your car all messy , i wanna see what you did with the 2d skirts
RB25 still has 160psi across all six, valve stem seals ??? (no smoke when boosted below 4k rpm)
Spare head being built, mild port job, full reco, gtr cams, solids and valves, no vtc. Will restrict oil supply, drill block and head oil returns whilst off, external return kit.
Just keeps going! lol
  • 1 month later...
  • 3 weeks later...
This is one tough 32 four door man. Love the GTR bonnet n grill combo on foru doors.
The '25 with the 3037S is tits! Nice man, love what your've done.
Keep up the good work!!!! :)
Thanks mate, step 1 RB30DET nearly ready just needs assembling
So far:
Rb25 head. light port, drillled, full reco, std cams, no vtc
RB30 Block, std bore, restricted, drilled and debured.
Crank collar, grub screw, linish and balance.
std pistons and rods, new rings,
new acl race main and rod bearings.
new N1 oil pump and waterpump.
genuine gasket set and cometic headgasket.
  • 3 weeks later...
RB30DET running :nyaanyaa:
Rb25 head. modified, drillled, full reco, no vtc, 20 inlet cam, 25 exhaust cam, dayco 94407 timing belt,
RB30 Block, std bore, restricted, 1xhigh/1x low tensioner, drilled and debured, genuine gasket set, 1.2mm cometic headgasket
RB30 Crank, collar, grub screw, linish, std pistons and rods, new acl race rings, main and rod bearings.
New N1 oil pump and waterpump, Greddy oil cooler and relocator, Greddy style manifold, 850cc, 2x 044 pumps, 1x 040 intank pump.
Still running GT3076 .63 with 38mm tial gate under manifold & same tune from rb25.
Going to move gate and plumback with new stainless dump then tune on E85.
Gold Coast 4 door <3 :D
We have 3x skyline 4 doors:
Mine, R34 4door and another R32 4 door, all highly modified
Pop in anytime:
FFF MOTORSPORTS
5/14 bailey crescent
Southport, 4215
Matt 0414 233 005
Edited by RED513
Pop in anytime:
FFF MOTORSPORTS
Southport, 4215
Matt 0414 233 005
Yeah nice!
Sounds good. should be on the road within the month ;)
i got a build thread in the build section.
have a good one.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
