hey guys got a 33 cut if anyone needs any parts let me know
the rb25det can be seen running and anyone who purchases it i will do a leak down test for.
s2 rb25det complete motor - 1500
rb25det box - 1100
rb25det manual radiator - 100
r33 front brakes and rotors $250
r33 rear hubs and brakes perfect for silvia or cef 5 stud (33 handbrakes work mint in these) -300
r33 rear cradle -100
r200 lsd diff -200
r200 5 bolt half shafts $100
r33 complete fuel pump assembily -$70
r33 mint tien coil overs $750
r33 5 stud front hubs -$120 pair
r33 steering rack -80
r33 front seats -150
r33 uras front barwith clear indicators-200
r33 clear guard indicators -50
r33 bonnet -250
r33 headlights-250
r33 guards -100 each
r33 brake booster-100
r33 clutch petal-50
r33 dash cluster 147xxx km -100
r33 dash with awesome jap spec stickers all over it $100
r33 front reo $80
r33 side mount cooler $40
r33 washer bottle -$50
r33 over flow bottle $50
r33 rad support and skirt cut $150
r33 diff back exhaust with cannon $50
greddy turbo timer old style - 60
r33 standard castor arms $20 each
r33 front wishbones $50 each
bee-r limiter bitchs -220
rb20det ecu-80
rb25det s1 ecu- 100
have lots of rb parts so pm me or txt me if there is anything not on the list your chasing
either pm me or txt 0434284753
thanks vance
rb25det box - 1100
r200 lsd diff -200
r33 bonnet -250
r33 headlights-250
r33 clutch petal-50
r33 front reo $80
rb20det ecu-80
rb25det s1 ecu- 100
thanks vance
Hey mate
these parts for series l or ll?
keen on the front reo, headlights what sort of condition are they in? and other few bits and pieces just sortin damage doneto mine at the moment, also need the bar that goes from guard to guard radiator supported by it?
anyway just registered tonight so cant pm ya yet probably give you a call tomorrow
Cheers,
Robo
here is a updated list i cant edit the first post for some reason
rb25det box - 1100
r200 lsd diff -200
r33 bonnet -250
passangers r33 head light black $100
r33 drivers guard-100
r33 clutch petal-50
r33 front wishbones $40 each
rb25de auto ecu -80
rb20e ecu-80
rb25det s1 ecu- 100
r33 hid kit high and low beam good jap brand $300
Edited by OGR88 R32
rb25det box - 1100
r200 lsd diff -200
r33 bonnet -250
r33 clutch petal-50
rb25de auto ecu -80
rb20e ecu-80
rb25det s1 ecu- 100
hey mate where r u located
Mate would you take $2000 for motor and box? What are the km's on the engine and does the gearbox still change smoothly? where are u located?
Cheers
Dale.
my number is 0447 461 636
hey i am looking to purchase the clutch pedal... and also a clutch master cylinder if you have one in working order!
AND, if you have the nissan logo boot lock i would also ove to purchase that.,.. let me know how much for these parts shipped to the usa thanks!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
