I'm parting out my GTST, most parts have only recently been installed and are basically new. I just don't have the time and patience for the car anymore so its all gotta go.
The long motor was purchased stock from a local import wrecker and has good compression on all cylinders, no leaks and ran well 2 weeks ago when i started it but i've got no idea how many k's are on it im guessing just over 100,000 since the timing belt i replaced looked fairly new. Cams, headgasket, timing gear was all done recently the bottom end hasnt been touched but the bores and pistons looked schmick when i had the head off.
GT35R .82 rear housing, 6Boost Manfold with black ceramic coating, Synapse 40mm Syncronic Wastegate, Water/Oil lines and HKS Bellmouth (no dump or cooler piping, only test run on the motor for 10mins tops) - $3000
RB25 Long motor with tomei pon-cams, acl race series mls head gasket, gates racing timing belt and new tensioner, greddy knock off plenum and VH45 Throttle Body (will include top feed injector setup with 650cc siemens deka injectors and aeromotive a1000 fpr for an extra $500, no ac or ps pump) - $2500
RB25 Complete Manual conversion (has exedy heavy duty clutch thats fairly worn although it didn't slip with the old motor at ~350rwhp) - $1250
BC BR Coilovers, HI-CAS Lock bar and Rear camber adjustment bars (only just been installed in the car haven't driven the car with them yet) - $1400
Haltech Platinum pro r32/r33 plugin ecu with extension harness, couple of marks on case but barely used - $1700
Clear side repeaters - $20
18" 350Z Touring V2 Rims, small marks on 3 rims and decent gutter rash on 1, 1 new tyre and the rest would have over 75% tread. - $500
Bosch 044 and 2.5L surge tank - $200
600x300x100 Intercooler, 3" inlet and outlet - $70
ASI 50mm Alloy rad and twin 12" Thermos - $250
VH45 Throttle Body - $100
Pics:
Everything is currently still on the car (if anyone is interested in the whole car lemme know) so if you want pics of certain things ask. The whole car is being parted (except the nitrous gear atm) so if you need something just ask everything has gotta go and i wanna get rid of it all asap so feel free to make sensible offers. Will separate items if i have buyers for everything.
Will add more later this week and get more pics.
Edited by slo_sprint
https://www.sau.com.au/forums/topic/325760-qld-parting-out-black-s15-r33-gts-t/
Pics:
interested in the 6boost manifold
fuel pump and surge tank
front facing plenum with throttle body
injectors and fpr
intercooler
pm me with best price for the lot
injectors and fpr
intercooler
Can't PM yet man, just so ya know the manifold has a Tial 2 bolt wastegate flange.
Can do it for $2200 but id like to sell the manifold with the turbo gear together or at least have buyers for all the stuff so i'll let ya know.
Anychance posting to 5173 Adelaide for $30
cheers
Can do
how old are the coilovers any leaks or knocks and spring rates etc?
cheers
Basically brand new, installed them and thats it so no knocks or leaks. Pretty sure the spring rates are 8kg front and 6kg rear.
Fuel pump and surge tank sold!
Better pics of engine in this gallery http://yfrog.com/0aimg0885hjx
pics of throttle body? will you send to wa?
Pics in the link above, will send to w.a. no dramas if you pay postage.
350Z Touring V2 Rims got pics of "decent gutter rash " one? how much to get it to melb?
Pics of all wheels in the link, no idea how much itll cost it'd be too heavy for aus post so i'll leave it up to you to organise shipping.
Hi mate,
How much for the greddy plenum and 6boost manifold?
Thanks,
Pete
I'd looking for around $1200 for the manifold and ill take $200 for the plenum but im not willing to separate them yet.
Where abouts are you located? Im interested in the gearbox conversion and radiator?
I'm in Sheldon in QLD man.
One VH45 Throttle body and clear repeaters sold.
C'mon people im wrecking a whole car here, panels, interior, lights, sunroof, suspension everything is up for grabs i need space for the new car.
Engine, turbo kit, ecu and manual conversion listed on ebay and will add more during the week
hey man how much do you want for your front bar and front left lower control arm? and do you still have the intercooler?
Front bar you can have for $30 but its in need of paint pretty bad the lca i dunno like $20?
im keen on the conversion kit.how much to post to melb? how many k's has it done? gimme ur number n i'll give u a buzz. cheers
PM Sent
Long motor with plenum and vh45 tb, turbo gear, intercooler, wheels, fpr injectors and rail all sold
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
