hey guys,
its all finally coming along with my suspension needs. having just sourced some drag radials and in the midst of combining a soft shock/spring combo and then finally ordering a 1.5LSD, ive started to think about what i can do to make sure drive shaft components stay together, or at least try to :rolleyes:
Don't know much about it but i was wondering;
How does the gearbox, tail shaft and other important components hold up with a 500hp rwd vehicle? what are the common weak links in a r34 gtt. and what should i be focusing on?
the car currently has a Nismo Coppermix Twin Plate which is mroe then enough for the 500hp.
p.s: the car is staying MT
any help much appreciated.
https://www.sau.com.au/forums/topic/325847-driveshaft-upgrades/
Two of these puppies for starters.
Diff and tailshaft don't usually have trouble. You have, are going to upgrade the diff center anyway.
Not sure if the 6 bolt flange on the GTR shafts will bolt up to the GT-T halfshafts that slip into the diff though.
thanks for advise sean,
apologies for the dumb questions but what exactly is that? is that the center diff? how much do these fetch for? and where can they be sourced?
dont aftermarket companies make these sorts of stuff?
how do the Rb25 gearboxes hold up?
Edited by Jap_Muscle
I know that some people put in a whole GTR rear cradle that has all the diff, shafts etc already there, Abo Bob is one member that has done the GTR upgrade, so he would be more helpfull with the details.
The 25 box is basically the same as a late R33GTR gear box so they are pretty strong, especially for RWD. Only weaknesses are third gear and synchros at high rev fast shifts.
Os giken and Par etc are a couple of gearset upgrades available.
http://www.skylinesaustralia.com/forums/R3...html&hl=gtr
http://www.skylinesaustralia.com/forums/Gt...html&hl=gtr
http://www.skylinesaustralia.com/forums/Di...html&hl=gtr
Buy complete r32/33 GTR rear cradle.
Use the axles, hubs and diff out of it .
Throw the rest in the bin.
If you want a 1.5 way you will have to get that done at same time.
Fairly easy exercise. Wont need to worrie about breaking axles again.
I have just done the conversion into my R34 GTT
This is the right answer.
I paid $700 from a mate for the the lot from an R32 GTR. My traction control stopped working, and presumably the ABS, although the rear isn't really a problem in most ABS needing situations.
I did it because I snapped a drive shaft.
you would probably wanna upgrade sway bar and traction brackets etc... rb25 box's are probably the strongest outta skyline boxes.... tail shaft will be fine... ur diff on the other hand might not last too long... if your serious and have the $ to back ya idd go borg warner 28 spline or 31 spline diff outta vl or r31... they run 9's in em just fine so you'd think they'd be good but you needa modify/change the brackets etc...
can the billet gtr driveshafts that hi octane fit into the rear without having to mod everything? from what ive seen they come as just the splined shafts
sorry just following up on this
if i put a gtr rear cradle in my car with a gtr 1.5 way diff can i use the hi octane billet drive shaft set
im in the same position as the op just with a shit load more power.
and ill be using the 25 box with os gearset inside it.
  • 4 weeks later...
^ be good to know that as wel. those babies look tough as.
i had a chat to SydneyKid (gary) not long ago and i remember him sayign that the R34 GTT already had GTR hubs and axles when Nissan built them?
i might have misheard but i do remember him saying the GTTs had similar drive train components to the GTRs. can anyone confirm what?
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
