Depends how accurate you want it to be. If you just want it as a pretty moving gauge that attracts some attention then go the cheapest. If you actually want it for monitoring your boost then you will need to spend a bit more.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307633
it doesnt have to be an expensive gauge to be accurate, just as long as it's a decent brand.
i'm using a vdo mech gauge right now. have been using it for a while. it's always spot on.
had a splitfire in the car when i bought it. seemed pretty good. autometer was also good.
i hooked up a calibre gauge. it was out by a couple of psi. autogauge, same crap.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307713
if they are inaccurate it wont be by much, if your only running stock psi or there abouts, just get a cheapo one, if your pushing pounds then you need a good one, as its important to know exactly whats going on with the boost at higher levels.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307716
Yeh it's not so much that they are out by much, although my old cheap vacuum gauge was out by 6 in/HG, it's more that they are prone to random inaccuracies which leaves you wondering if something is wrong or if it is just your gauge. If you are going to buy cheap then I would recommend getting a mechanical gauge, they tend to break easier but are more accurate than an equivalently priced electrical gauge, the cheap stepper motors just don't cut it. If you want electrical then I would spend a little bit more and get a decent gauge.
https://www.sau.com.au/forums/topic/325958-boost-gauges/#findComment-5307814
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
