  • Replies 91
i want to tune my car on e85, i heard it can be bad on fuel lines, tank etc.
i have 555cc's in might car an hope to push around 300rwkw with them on e85.
but would i have to upgrade them due to e85 needing 30% more flow capability than PULP?
so goes the theory, however i would be interested to see the consumption and duty cycle figures of someone who keeps the same injectors and boost level, and literally just involves a retune to calibrate the ecu for the type of fuel... before and after would be excellent, esp if we can get a gas analysis report along with the air/fuel ratio
-D
-D
i think the consumption is around 30% more too, but some solid results will tell more
just to give you an idea of the extra duty cycle my car seen between e86 and pulp.
injectors are 90lb bosch ev14 (about 950cc) 044 fuel pump.
PULP tune 20psi 275rwkw 47% injector duty cycle.
E85 tune 22psi 334rwkw 90% injector duty cycle.
this is on standard rail pressure so there is more in the injectors with more rail pressure.
so in otherwords i need 800 or 100cc injectors?
you might be able to get away with them but would need alot of rail pressure. would be best to ask adrian (180or200). if it was me i would try to tune it on the 555cc just to try and save the $800.
if in any case you need injectors, ive been able to import US injectors for sau members before at the cheapest price avail (depending on exchange rate of course)
luke got 1600cc injectors or something ludicrous, chad got 1000's, and i think matty got 700's if not 555's along with dion
my 575's are running great in my engine. however i have other issues that need fixing (wont go OT)
if you need 30% more fuel and u get 30% + more power I would say its a practical upgrade, as you're sacrificing range for power (assuming the fuel tank wasnt enlarged).. its an unavoidable trait with e85
incidentally, some environmentalists are claiming e85 is dirtier than p98 oct. this is true in a sense, it develops more soot, however the soot is heavier than air and it makes its way into the soil. Studies done in the 80s which compared unleaded and leaded fuels found that in the long run the leaded fuels were better >for air quality< than unleaded as the lead oxide would cause the element to sink to soil level and be absorbed in the dirt
obviously, this is a bad thing for farmers, and anyone who deals with soil of any sort, however it proved that a heavier element would be more environmentally friendly than premium 98.
e85 by products actually are heavier than premium - they form a soot which sinks to the ground, but from what my limited understanding about petrochemicals entails, the carbon sinks into the ground and gets absorbed from the atmosphere the same way the old leaded petroleums did.
Of course there is also a multitude of environmental concerns regarding ethanol based petroleum, I think it will come down to being able to efficiently generating the substance as a by product rather than actually consuming more electricity than it puts out via its distillation process. (Not an issue if we have nuclear power stations and cheaper electricity but since we're a bunch of backward mofos we cant really expect anything great)
E85 - Awesome in theory, but some fundamental issues need to be addressed before we can expect it to be common enough for daily use.
Wicked for racing but. Just as indycar (they run methanol but hey, its not that much different)
-D
-D
I dont want to get into a debate here, but will say this, I dont like how the yanks make e85 with corn crops, thats just wrong, I do like how csr use a by product.
I cant argue about the soot as I havnt researched that, I would be suprised if there were any elements worse that unleaded, Unleaded is a disgusting fuel! one bonus about running E85 is it burns cleaner and doesnt leave the rear of my car dirty, unlike 90% skylines around. Check out Guiltoys e85 thread, he took his car in for emision tests in NSW and passed easily, running 330+ Rwkw from memory.
As for a injector duty, pound for pound 30% duty on a power fc sounds about right. But who wants to run same boost!
AD
I'm not after the 85rwkw that Krishy was talking about - I'd be happy with going 273@18psi up to 310-320@20+psi
700-750cc injectors see how we go.
Yeh I got my 1600cc off Dohmar. After reading about that guys 32R which maxed out 1000cc injectors at 23psi I thought I would rather be safe and go with these big sprayers.
they do make you a sad panda at full boost tho =(
but i'm so close to getting on to e85 myself, car has been rebuilt with it in mind, just need some new coils and it should be interesting to see what it makes =)
why do u say they make u a sad panda at full boost?
are the injectors dohmar gets a direct fit or do they need mods?
might hit up 1000cc to give me room with e85
even thou i have 740cc atm..
theyre direct feed low impedance top feed denso style injectors
so if you have an rb26 then yes, they are a direct fit
they also come in 1800 and 2000cc variants
-D
Only thing i dont understand is, when they said the 1600cc are direct bolt in, the info on the bosch website say they are 14mm and therefor would not fit in a stock gtr rail, being 10.5mm :s
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
