As above - currently using μTorrent, but lately hasn't been downloading as fast as it used to. I usually download PPV events - is the speed dictated only by the amount of seeds/peers, or is software a factor too?
https://www.sau.com.au/forums/topic/326186-torrent-software/
What sort of connection do you have?
In my experience the seeds and peers is obviously the biggest factor besides your connection. Also throttling back your upload speed will have a detrimental effect on your download speeds too. Here in Australia we are often limited by our upload speeds because torrents automatically give the better download speeds to those people uploading at a faster rate and those people are usually in North America or Europe. I think Utorrent is the best client, it uses the least amount of system resources and seems to give the same if not better speeds than other clients. Also Utorrent is the preffered torrent program for most of the private trackers I know of.
UTorrent IMO is the best for Windows based applications, it's light and fast. What you want simple software to be. However UTorrent has some very powerful config settings that can cause problems if you set up wrong :)
Seeds/Peers are a factor however there are also other factors to consider as follows.
UPnP
The UPnP setting (set the port to something over 50,000). Some ISP's will monitor ports below 40,000 and artificially shape your connections/requests originating.
I've found simply changing a port number to restore speed in some instances.
Global Connection Limits
Also there are some other settings that can be configured like the "number of global connections".
It is possible to MAX your router out with too many connections which will actually cause it to slow down.
I would assume (given you are asking such a question), that your router is not really high end so you want to set MAX Global connections to no more than 800-1000.
Active Torrents
Another thing to consider is the amount of active torrents you have.
There are limits within UTorrent, so have a look. If you have 100 active torrents (upload & download) then if you try for 101, it will give priority based on those which are active.
A torrent doesn't have to be seeding/downloading to be active either. If it's updating the trackers and so on i believe this to be counted as active so try bumping that number up by 50.
Or simply cleaning your current torrent listing (if you dont need them all active etc)
Checking Router Sync
Not sure if you know how to check what your Router is Sync'in @ with your ISP. But if you do - have a look and let us know.
Then also tell us your MAX download speed. You might find there is an issue with Sync speed and UTorrent is only running as fast as your connection currently allows.
Give the above a crack and report back :(
There are some other things you need to change, but for the life of me i can't remember so i'll check when i get home and update then.
lol - Just happens that cars & internets are my prime interests... Hence a forum with car stuff is gold :)
If you can check the router sync speeds - IMO that is probably the best place to start (even though its last on the list)
I dont understand how people can still use torrents, i used to use it, but only with private trackers like demonoid, supertorrents ect...
Direct downloading from rapidshare/megaupload is seriously the way to go, no wait, full speed, heaps of forums that act like catalogs to all the links, and really $10 a month (or $20 3 months, $100 lifetime) is worth it, in conjunction with IDM, downloading really doesn't get easier.( i also blow 250gb a month hording the internet)
lol at demonoid being a private tracker.
get on any half decent tracker and torrents are teh best.
OP: uTorrent for windows, there is no other option.
Lmao sorry man, I ended up hacking away at the settings being the noob I am - but it worked so I'm happy :P
:):laugh:
:laugh::laugh:
Damn you to hell boy! LOL!
PC Trouble shooting 101 - step by step.
That way you know for next time what to look for ;)
And i like to know for my own knowledge of what sometimes can go wrong (sometimes updates cause problems etc)
I'm a cheap ass Asian... that is a lot of unnecessary spending for me... :)
EDIT: also would like to point out that I used to torrent using a dial up connection (sync at 48kbps) so I'm very tolerant of waiting for it to finish.
Edited by Mayuri Krab
Yeah, that's what attracted me to it in the first place because I use my netbook for downloading/surfing whilst in bed lol
giggity!
usenet.
/thread
too hard to use, i just want to think of something i want, and 3 clicks later be downloading it
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
