hey guys
r32 got t-boned sitting in the driveway by a drunk driver (dont ask)
needs to go... $3.5k complete
12x,xxx on engine/chassis
out of rego
reco rb20 box and brand new heavy duty single plate clutch (under 1,000kms ago)
brand new DBA rotors front and back
full exhaust
tein coilovers
N1 GTR genuine bonnet and lip
fiberglass GTR wing
moulded japanese rear guards (30mm - unsure of brand?)
25mm vented front guards
assorted gauges/jvc head unit
18" rims (can be sold seperately)
have a spare BN rear bar + 6x r32 standard rims with tyres and some stocky bits
located in SA near the bay
definitely repairable damage... could be re-registered as there was no insurance so it hasnt been "written off" or could be a good track hack with some bashing/welding
Edited by Hella Flush
very interested in the car. had to tell from the pics but it looks like the only things damaged were the door, side skirt and rear pannel. is there any structual damage to the door frame?
slight structural damage to the frame and sil panel aswell as floor pan...
it can definitely be fixed and repaired and you will end up saving a few k compared to buying a non damaged one...
youre more than welcome to come look at the car
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
