The shell and most major mechanical items have gone so only the parts listed are still for sale. Was a silver S1 Stagea but most parts left are common to S2 as well. Selling my house soon so all have to go. Most of these items except for the doors and spare wheel can be posted to you at your expense:
Rear doors in excellent cond c/w cards, switches, electric windows..
Right rear $60
Left rear $50 (no window motor)
Ashtray $15
Lighter plug $10
Clock $20
Auto gear shifter $30
Head Rest $10
Centre Console $50
Space saver spare wheel $20
fuse boxes $15
Plate between boot floor & bumper $10
Fuel filler flap $10
RH Rear cnr tail light $30
Fibre spare wheel cover $10
ABS unit $30
Stock front castor rods $15 ea
Speedo drive $20
Front sway bar $20
https://www.sau.com.au/forums/topic/326404-stagea-s1-parts-to-clear/
Hi do you still have the right/drivers side
For Sale??
How much to post to OZ??
its quite urgent you can sms me on 0449 544 904
Thanx
PM sent
BTW Castor rods are not off crashed car they are off my current car (fitted adjustables instead)
ps Clock sold
  • 4 weeks later...
Right rear $60
Ashtray $15
Lighter plug $10
Clock $20
Head Rest $10
Centre Console $50
fuse boxes $15
ABS unit $30
Speedo drive $20
Front sway bar $20
Doors, clock, autoshifter, ABS unit gone. Also have fuel tank sender unit for guage $20
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
