Hey all,
Ive still got a Non-Turbo R33 for sale, its a 2 door, 1994 model. Its got 293,000kms but doesnt burn any oil or water and is very reliable. It cant be defected!
Its got some mods:
- Apexi coilovers
- 3A Racing Exhaust, with papers so cant be defected
- 1 year old tyres (235/45/r17)
- 17" rims (chrome peeling)
- Alpine S-type splits 6"
- Tinted windows (faded in parts)
- Paint is in not real good condition
- Interior is in pretty good condition with a small rip in the drivers seat
- 5 speed manual
- Apexi pod filter (with standard panel filter currently installed so cant be defected)
Im in Armidale (NSW) but can do a bit of travelling to meet people half way if they are serious.
I was origionally asking $9,000 but im sick of people not following up on purchases, so i just want a quick sale, and the price is FIRM.
If you are interested, my email address is [email protected] or my phone number is 0432063687
Cheers,
Chris
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
