Front Headlights - Immac Cond, Pair - $200 both or $120 ea
Doors - Drivers side Gun Metal Grey, Passengers Red - both incl windows, no door cards - $250 ea
Side indicators - Orange, Good Condition - $30 ea
Dash - Immac cond no holes bubbles or cracks - not incl vents and other plastic parts - $100
Rear Seats - Both Halfs, Good cond. no tears - $180
Windscreen - $200
Drivers Qtr window - $150
Gab Rosso, Adjustable Coilovers - Good Working Cond. - No C Spanners - $550
Std GTR intercooler - $120
Radiator - $120
Power steering Res. - complete - Wiring, cap etc - $70
Coolant Res. - Good condition no cracks - $70
Windscreen wash red - good cond no cracks $70
RB26DETT PARTS
Valve Spring Caps - $60
Std Cams - $80
Std Cam Gears - $60
Rocker Covers - Both Sides, Orig Black, surface is a little rough but not too bad - $200 both
Cam Cover - Front, Reads RB26, Orig Black, same as above, $80
Power Steering Pump - Complete, Working, - $80
Inlet Plenum and Throttle Bodys - Good Cond all linkages etc. - $300
Clutch Fan - $50
Coilpack Wiring Loom - $30
Engine Wiring Loom - Complete - $160
ECU - $100 (if purchased with engine wiring loom $250 for both)
Std Coilpacks - Good Cond. - $200
other parts available but not yet off car,
ALL PRICES ARE PLUS SHIPPING FROM PERTH
PM me, reply in here or text me on 0422648745
all needs to go soon!!!
Thanks
Daniel
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/
PRICE DROPS!
Front Headlights - Immac Cond, Pair - $200 both or $110 ea
Doors - Drivers side Gun Metal Grey, Passengers Red - both incl windows, no door cards - $240 ea
Side indicators - Orange, Good Condition - $25 ea
Rear Seats - Both Halfs, Good cond. no tears - $160
Windscreen - $180
Drivers Qtr window - $140
Radiator - $100
RB26DETT PARTS
Std Cams - $80
Std Cam Gears - $40
Inlet Plenum and Throttle Bodys - Good Cond all linkages etc. - $280
Clutch Fan - $40
ECU - SOLD
OTHERS:
Std Exhaust manifolds $60 pair
Head Studs - $60
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/#findComment-5317054
BUMP! :) 500 for the coilovers :)
chasing all parts to convert my gts4 to manual, pm me if box, drive shaft, clutch, clutch and brake pedals, and master and slave cyls are still available... cheers and your best cash price freighted to kingsthorpe QLD 4400
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/#findComment-5323944
  • 2 months later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
