Front Headlights - Immac Cond, Pair - $200 both or $120 ea
Doors - Drivers side Gun Metal Grey, Passengers Red - both incl windows, no door cards - $250 ea
Side indicators - Orange, Good Condition - $30 ea
Dash - Immac cond no holes bubbles or cracks - not incl vents and other plastic parts - $100
Rear Seats - Both Halfs, Good cond. no tears - $180
Windscreen - $200
Drivers Qtr window - $150
Gab Rosso, Adjustable Coilovers - Good Working Cond. - No C Spanners - $550
Std GTR intercooler - $120
Radiator - $120
Power steering Res. - complete - Wiring, cap etc - $70
Coolant Res. - Good condition no cracks - $70
Windscreen wash red - good cond no cracks $70
RB26DETT PARTS
Valve Spring Caps - $60
Std Cams - $80
Std Cam Gears - $60
Rocker Covers - Both Sides, Orig Black, surface is a little rough but not too bad - $200 both
Cam Cover - Front, Reads RB26, Orig Black, same as above, $80
Power Steering Pump - Complete, Working, - $80
Inlet Plenum and Throttle Bodys - Good Cond all linkages etc. - $300
Clutch Fan - $50
Coilpack Wiring Loom - $30
Engine Wiring Loom - Complete - $160
ECU - $100 (if purchased with engine wiring loom $250 for both)
Std Coilpacks - Good Cond. - $200
other parts available but not yet off car,
ALL PRICES ARE PLUS SHIPPING FROM PERTH
PM me, reply in here or text me on 0422648745
all needs to go soon!!!
Thanks
Daniel
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/
PRICE DROPS!
Front Headlights - Immac Cond, Pair - $200 both or $110 ea
Doors - Drivers side Gun Metal Grey, Passengers Red - both incl windows, no door cards - $240 ea
Side indicators - Orange, Good Condition - $25 ea
Rear Seats - Both Halfs, Good cond. no tears - $160
Windscreen - $180
Drivers Qtr window - $140
Radiator - $100
RB26DETT PARTS
Std Cams - $80
Std Cam Gears - $40
Inlet Plenum and Throttle Bodys - Good Cond all linkages etc. - $280
Clutch Fan - $40
ECU - SOLD
OTHERS:
Std Exhaust manifolds $60 pair
Head Studs - $60
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/#findComment-5317054
BUMP! :) 500 for the coilovers :)
chasing all parts to convert my gts4 to manual, pm me if box, drive shaft, clutch, clutch and brake pedals, and master and slave cyls are still available... cheers and your best cash price freighted to kingsthorpe QLD 4400
https://www.sau.com.au/forums/topic/326632-r32-gtr-parts/#findComment-5323944
  • 2 months later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
