Hi All,
Trying to find a way to attach eyelids and bootlip to an r34 sedan. I've done searches and people are recommending sikaflex or 3M heavy duty thin double-sided tape.
I've been to a few hardware stores and had no luck finding the tape and the dudes at bunnings tell me that sikaflex is pretty much permanent.
Anywhere around Perth I can find something that will stick these two down nice and firm without being too permanent (ie: don't want to drill holes etc or have them permanently glued)
I've tried Bunnings in Innaloo and Balcatta with no luck - any tips appreciated fellas.
regards,
Steve
https://www.sau.com.au/forums/topic/326766-attaching-eyelids-and-boot-lip/
hey this stuff should work used it for the skirts on my car haven't had a problem.
it is a bit pricy but works well. but make sure you really push it on and don't get any bubbles in the tape.
http://www.tapesonline.com.au/double-sided...bond-clear.html
Cheers bud will definitely give it a go, the eyelids I'm not overly worried about but I don't want anybody ripping off the spoiler and running away =(
I was going to use Sikaflex but I'm not sure which one to get (there are about 10 variations). And I also don't know if they will cause any permanent damage to the paintjob or plastic eyelids.. I believe fishing line gets the part off but I'm not sure about the residue etc..
yeah this shouldn't mark the paint and you can get rid of the sticky shit easy with some alcohol (not drinking alcohol).
with the lip make sure you get lots of contact area, i think this stuff holds like 17kg per metre at 1cm wide so is pretty strong.
hope it works for ya.
Oi Steve, if your after Sikaflex, give me a call, I got Sikaflex in black, used it on my side skirts on the R33 awhile ago..
Thanks bro, I'll let you now.. first i gotta paint those bastards... causing me so much trouble!!
PS: stop buying a new car every week (but feel free to buy me a car)
-Steve
-Steve
haha I'll try but no promises :P
yeah give us a buzz on the weekend or something, still got bulk sikaflex left, pretty much like brand new haha, talk to you then.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
