How much boost do you run? I'd be too concerned about the joiner blowong off the back of the afm. There is no lip on the afm to help hold it on. Ive also heard that Z32 afm's can be abit funny when used in a blow through system.
It's a fairly common practice relocating an AFM to cold-side piping when upgrading turbos, especially for those who prefer not to/can't use an ECU like a d-jetro or an EMS 8860 which do away with the AFM and run a MAP sensor.
Haven't heard of many cases where the joiner has blown off the AFM, but I suppose it does make it susceptible given it clamps onto a flat surface.
Edit: Also, to the OP, is this a high mount setup or on a low mount?
Edited by d1_drifter
For a flat surface. Drill say four small holes and put in self tappers. This gives total resistance to the hose blowing off. When the clamp comes up against the heads of the s/ts it cant move. Easy and cheap.
When setting the front facing plenum all the flat surface joins blew off. Why wont this SOB go???? LOL
Where is the bov in that engine bay??? Can anyone confirm the z32 not working in a blow through. Or will stock be fine for 16-18psi?
thats Simon-R32's drift car LINK to Build Thread. and being a track car having a bov probably isn't something he is worried about.
the maf will work blow through, it just depends on how you set it up, i've just heard that the Z32 can be a bit sensitive as to where you place it. couple of things to keep in mind are, the afm housing isn't designed to take pressure, and unless you have a good oil catch can setup you maf will need constant cleaning and the oil contamination may even reduce its life. i have seen a method where the hotwire was removed from the plastic housing and mounted into a steel i/c pipe which would help with the pressure and joiners blowing off.
a couple other options if you really want to keep a larger size inlet is to get a Q45 afm, they are 90mm which is just under 4". or track down a ford lightning maf which is also 90mm i believe, and is compatible with nistune.
but reducing the turbo inlet down to 3" is fine and will save you alot of trouble. i have my GT35 setup like this runnning 16psi (soon to be more) and without an issue, GT35 also has a 4" inlet. personally i wouldn't worry about it, 3" pipe will be easier in the low mount position, its very tight for space down there once all the i/c piping is in.
Edited by QWK32
I got a 4" to 3" silicone reducer and made up a S/S inlet pipe. Just welded in some nipples for the oil breather and bov return. Then used another silicine joiner to connect the steel pipe to the afm.
I did the same with a alloy bend and retained the stock airbox and airflow meter location. Keeps things nice and quiet. A few people have complained how loud the antisurge 4" inlet can be with no airbox and a pod used instead.
sorry if this is getting repetative but i want to be sure im doing to right thing as i need my car everyday so off the road time needs to be minimal. does everyone agrees gt3076r with .82 rear/oem bolt pattern, 4"-3" reducer off turbo then alloy/steele pipe to afm, 2" elbow into stock i/c piping??
only concern i have is will my car run on 14psi as it sits or do i need to do the fuel pump and nistune before i can drive it?
.82 rear housing does not come in an OEM 6 bolt pattern to the dump pipe. It is 5 bolt, so custom dump pipe
Need a 2" to 2.5" silicone reducing bend onto intercooler pipe. You will need to replace the cooler pipe as well to clear the 3" inch inlet pipe.
I could keep going, but I won't because fitting a gt3076r IW .82 is not straight forward and EVERYTHING need to be modified to get it to fit. Allow alot more than one day to fit if you do not have everything ready before hand.
I am running 14.5psi with mine making 245rwkw, so you will need the support mods to suit
What EXACT turbo do you have and what fitting parts do you have as well?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
