hey guys n girls,
I am re-posting an old topic where i tried to sell an rb25 neo engine for very cheap but sales fell through.
this engine is out of an r34gtt manual.
The head is in good condition and comes with all stock parts including coilpacks, injectors, cam gears ect.
bottom end needs new bearings and possibly rods and crank.
Inspections are welcome.
does not come with a turbo, radiator, alternator and such items so basically a long motor.
want 800 as a whole or make offers for the parts as i will srtrip for right offers
I have already had some offers for engine and parts but have been a bit to low
good excuse for a rebuild project if anyone is interested!!!
call me on 0422464760 or pm me for more information
https://www.sau.com.au/forums/topic/326895-rb25det-neo-engine-for-sale/
  • 4 weeks later...
dont have time to separate anything,
if you guys want buy it off me for 600 and separate between you, im hardly ever at home so cant help.
still $600 for the whole engine!!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
