maybe your needles stuffed..mine is tells me all sorts of strange readings, i can fill up and it will say 3/4, or like today ..i was driving out to Macedon and the needle was on a quarter...f**king thing ran out of gas ..luckily its dual fuel :D
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321518
mine does it too, sometimes I have 3/4 of a tank and if I'm in traffic for ages it will drop right down below E and no light. Then if I accelerate hard or corner hard it comes back up. Dunno why it does it but it's random so I don't care. I know how many kms I get from a tank on everage so I don't worry about it.
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321568
It does it because the sender for the fuel indication is on one side of the tank. I have found out during a skidpan day. If you keep turning right in circles it will show that you have less fuel than you really do. Turn left the needle will show you have more fuel that you really have. Pretty standard stuff :D
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321728
I think they are designed like that to hint that you need to fuel up soon. My evo and gtr both do the same thing. First half takes longer than the second half.
Sounds about right to me, all the cars i've ever driven have been the same way especially those without the fuel light. Of course if you own a VP Commodore you just go by the odometer because you know off by heart how much you get from a tank :)
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5322151
Sounds about right to me, all the cars i've ever driven have been the same way especially those without the fuel light. Of course if you own a VP Commodore you just go by the odometer because you know off by heart how much you get from a tank :/
I thought the rule of thumbs with Commodore was drive to the next petrol station after filling up and you should be right...but carry a jerry can just in case :P
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5323042
My car has run rich for the last ... Well... Ages. My o2 sensors are gone so the car reads it wrong n uses too much petrol. Might be that. Good news for u is that given u only have one instead of two expensive parts for it like I do... It'll cost u about 100 odd instead of 500 :/
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5323220
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
