maybe your needles stuffed..mine is tells me all sorts of strange readings, i can fill up and it will say 3/4, or like today ..i was driving out to Macedon and the needle was on a quarter...f**king thing ran out of gas ..luckily its dual fuel :D
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321518
mine does it too, sometimes I have 3/4 of a tank and if I'm in traffic for ages it will drop right down below E and no light. Then if I accelerate hard or corner hard it comes back up. Dunno why it does it but it's random so I don't care. I know how many kms I get from a tank on everage so I don't worry about it.
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321568
It does it because the sender for the fuel indication is on one side of the tank. I have found out during a skidpan day. If you keep turning right in circles it will show that you have less fuel than you really do. Turn left the needle will show you have more fuel that you really have. Pretty standard stuff :D
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5321728
I think they are designed like that to hint that you need to fuel up soon. My evo and gtr both do the same thing. First half takes longer than the second half.
Sounds about right to me, all the cars i've ever driven have been the same way especially those without the fuel light. Of course if you own a VP Commodore you just go by the odometer because you know off by heart how much you get from a tank :)
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5322151
Sounds about right to me, all the cars i've ever driven have been the same way especially those without the fuel light. Of course if you own a VP Commodore you just go by the odometer because you know off by heart how much you get from a tank :/
I thought the rule of thumbs with Commodore was drive to the next petrol station after filling up and you should be right...but carry a jerry can just in case :P
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5323042
My car has run rich for the last ... Well... Ages. My o2 sensors are gone so the car reads it wrong n uses too much petrol. Might be that. Good news for u is that given u only have one instead of two expensive parts for it like I do... It'll cost u about 100 odd instead of 500 :/
https://www.sau.com.au/forums/topic/326982-is-this-normal/#findComment-5323220
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
