What would i be facing if i removed my cannon compleatly, and put a straight piece of 3" in its place? Also, if i was pulled over with this kind of system what would the punishment be? An instant fine on the spot and being told to put the muffler back on? Or a defect and having to put the muffler back on.
Also are defects actual fines? Do they cost anything at all? Or what would a fine for this cost? Has anyone ever done what i want to do, and ever been pulled over for it?
Oh, and the system will still include a cat, and a resonator. If that helps...
https://www.sau.com.au/forums/topic/327066-qld-defectsfine-amounts/
assuming you did get pulled over sometimes they are just lazy and are like "thats too loud change it over"
or they could be like "im defecting you for exhaust" i think its normally $150 fine and have to appear in court (the court part doesnt mean much is just to waste your time)
or the worst outcome would be they send you to the pits for a full inspection, to survive one of these you basically need to return your car to stock
a mate of mine got defected while driving his mates 4wd. think it was a $110 fine and 1 point, plus having to put the car back to being legal. he was defected for a lift kit, or tyre size or something like that.
may i ask why you want to do it? performance wise you won't gain anything, you will just be making the car louder (am assuming that is the goal?). having said that, a turbo car without the rear muffler isn't that loud. you may get away with it, but if you do get pulled over for it, then make sure you don't have anything else illegal because there is a chance they will then go over the car. so if youre tyres are getting low, or you have an atmo bov, or have cut the front reo to put a cooler on then expect to also be done for them too.
Yes, the main idea is to make it sound better, and louder. But it sounds like its just going to be a cop magnet, and with my other mods, it would cost a small fortune to restor most of the things on it.
My only other option would be to sleeve the muffler with a piece of 3". The only real thing they could book me for is excessive noise, so possibly, like you said $100-$200 fine and maybe a point. And the cost of a new muffler.
Really it dosent sound like its worth it. I feel like im hooked on the noise drug...
it will make a bit of difference, but the point is that the cops wouldn't book you for not having the rear muffler there (so sleeving the muffler is pointless), or for having the resonator removed. they don't care about that. they will simply book you for how loud the car is, and once they are booking you for one thing they will look to see what else they can book you for.
that said, a few guys round here have been running twin 2.5" shotguns out the back of the car with either just the centre muffler/resonator, or no mufflers at all. most of them have been booked for it though. only know 1 out of them who hasn't.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
