bride or sparco
38 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hay dude.
in ur for sale thread it says that u would do cash adjustment + r34 parts
i have an r34 cooler kit and arc airbox (i got a full neo engine if u want lol)
let me know what parts ur after as i have many
cheers
julz
Makes sure you get the FIA approve zeta 3 as they make a non-fia approve which is cheaper.
If i remember right the fia zeta 3 is 75,000yen for fiberglass back and 150,000 yen for carbon back. Price does not inc rail
yeah thanks dude ive looked into that already. cheers
