hi guys.
i have just moved from melbourne to adelaide. i have to get a regular service for my skyline. which place can u people suggest?
i live at prospect and work in the city, so any place nearby would be great for me.
also i noticed today that my rpm meter is flicking off big time. it used to work properly before. today i noticed that it justs flicks back-and-forth big time even for a small push of the accelerator.
hope someone can help me out.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/
hi guys.
BAD/dirty ground on the sensor connection most likely , unless you have hacked into the ECU harness, then look at that connection for loose wires ?
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5326167
they seem to do awesome work for me everytime.....so its a +1 for me but might be a wee bit out of your way
boostworx do really good tunes and know what theyre on about
my preferred mechanical workshop is literally a street over, so I get mechanics done at Road & Track but get the nistune done by Shaun @ boostworx - I asked pete from PLMS who he would recommend for nistune specific tuning and he said shaun, and he was able to diagnose a fundamental error in the TDC setting on the stock cams.
Between the two workshops, you cannot go wrong
-D
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5326464
a big negative on boost works.. :ninja: going to last like 10 mins i know but worth it to save a sucker his time, car and money!
driving home after my 100k service to the 260.... sorry mate the work experience guy looked after ur car...
snapped BRAND new water pump
smashed radiator
spark plugs were done up very tight by hand.... could just get them off....
stilt brake fluid all over the brembos
i learnt the hard way to stop being lazy... save ur money mate... go speak to ur local repco and get them to sort you out
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330267
how do you snap a water pump :P
and what did Shaun do for you about it
big deal things happen its how the workshop fixes things after they realise some thing has happened
i had brake lines fitted @ boostworx one of there former mechanics put them on and when car hit the road line was touching rim i cut 1 line Shaun couldn't be more apologetic and sent me to JIS to get a new line and it got sorted there and then same day
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330329
another +1 for boostworx.
Its not that far from Prospect - I'm at Enfield and its only a 5min drive.
I've only had good experiences - prices are good, they explain everything, and are passionate about imports.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330489
True Steve........I've been around long enough to know that EVERY workshop has a horror story, BUT, it's how they handle you after the event.
Don't judge a workshop by their demeanour when everything is going honky dory, judge them when their backs are up against the wall......something my Dad used to tell me about the test of a person's true character.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330508
a big negative on boost works.. :ph34r: going to last like 10 mins i know but worth it to save a sucker his time, car and money!
smashed radiator
another -1 for boostworx. they told my wife that the ticking noise in her CA was just normal sounds that you get in the head, over time. "don't worry about it" they said.
it was a piece of the piston floating around the chamber with a bit of the top ring... fortunately we moved to QLD about a month later. unfortuantely, we drove the sil up. it got us to qld, but that was about it.
Edited by pyro-ns
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5332494
As Steve and Sled have said.
Shit happens to the best of people. It's how they fix the problem.
I'm going to Push Morpowa. Simon and the guys there are great.
There more up your area also.
Morpowa
Also recommend Simon from Morpowa, my R34 used to run like a dream when I collected it after every service. He knows his shit.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5333404
ive gone to quite a few different places to get things done to my cars and theres a huge list of who id never use again.
but ive been really happy with smooth garage and willall racing.
prices are good, service is good and they both know what their doing!
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5333714
wel they didn't f**ken handle me very well all Boostworx said to me was "we just blew your motor on the dyno by leaning out piston 6 and blew the ringlands, you can come pick your car up now"
NO APOLOGY at all especillay after i had just spent over $10,000 there!!!!!!!!!!!!!
-10000000000000
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5334511
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
