Got a heap of tyres/rims i want to get rid of so here they are
2x 225/40/18 Nangkang Ultrasport NS-II 90% tread
The tread on these is still huge, although one of the tyres has a worn edge from epic wheel flushness. The tyre in question still rides and holds air perfectly fine
although i would recommend drift/skids only
$40ono
4x 245/40/17 Khumo Ecsta V700 Semi slicks 75% tread
These have only done a few track days, 2 of them have more camber wear than the rears and a couple have flat spots from braking. Would be fine again after a couple of laps
or a skid. Havent had a chance to re use them after the track car broke so i dont need them anymore
$200
1x 125/90/16 Bridestone Space saver (5 stud 5x114.3, was from R33)
Still basically new, if even used.
$20ono
4x ROH Adrenalin 17x8 +30 5x114.3 with 235/45/17 Potenza GIII's 65-75% tread
These were on an R33 which had a battle with a gutter. The rim in the pick is pretty much the worst one and has a gouge out of it. The others were no where near as bad,
can get pics of individual rim on request. Still perfect for skid/drift rims and still roll straight (had them on jzx100 for RWC). Tyres have heaps of tread too
$300ono
3x Rodney Jane Racing wheels 17x7.5 +38 5x114.3 with 4x 235/45/17 tyres 90% tread
These wheels were on a R33 which was hit in the side, 2 of the rims are like new just like the tyres. 1 of the rims was destroyed which i still ahve the tyre (need to
check for cuts) and 1 of the rims there has a bent lip, you may still be able to use for skid/drift i dunno
$150ono
4x R33 turbo stock rims 16" 5x114.3 with 4x 205/55/16 tyres 85% tread
These wheels were obviously from an R33 which was a write off. 3 of the rims are fine, 1 has a crack on the back of the rim on the lip. Perfect for skids/drift. Tyres are
all in RWC anyway.
$100
4x AVON Full slick 250/620R17. Best suited to a 9-10" rim. I Have done one outing on these at winton. No longer need them, tread is still in excellent condition as you can
see from the wear indicator. These are a well known brand and a pretty wide slick
$300
All items located in langwarrin, contact me via PM or reply here as i will check this regularly.
Cheers, shane
Edited by shanet
https://www.sau.com.au/forums/topic/327441-vic-rims-tyres-slicks/
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
