Are you blowing gears or making loads of power? Standard GTS-T and GT-T boxes are very strong...
No cheap way about it if you want to uprate, will cost you a few grand for an uprated gearset...plus reconditioning and installation...are you prepared to spend that kind of money?
Give it up fool. Third gear is a common breakage in GTR boxes even in standard vehicles. Pushing 400kw with a heavy duty clutch during motorsport and you expect a non run-in reconditioned gearbox to hold up to that...you're dreaming.
Gearboxes and life expectancy are the length of a piece of string - you could get away with 600kw through a standard gearbox if all you do is drive to the shops and dyno days. Give it some stick and it's another story.
For the record GTS-T and GT-T boxes are known to be stronger than GTR boxes (excluding 6 speed) despite sharing similar internals.
GTR & GTS-T boxes are pretty much the same.
They are not "weaker" as such, it's just the big RPM launch + 4WD = death with the added stress and usually 2nd or 3rd gets stripped.
For a daily driven GTR, that doesn't get treated to nasty launches and driven with some mechanical sympathy there is no reason you can't make 380rwkw and be fine.
That said, you never know the condition/life of the gearbox half the time so inherrantly you might not treat it poorly and it will still give up the ghost anyhow.
Given we are talking a GT-T here, my first post stands.
We are not talking about GTR's of which the answer isn't quite as simple.
Its not so much the power your making but the torque.
Being rwd youll have it easier then awd cars. running semi/full slicks will cause more issues. also if you have a harsh clutch that can play info things as well.
Finally (and what i believe is the biggest factor) if you drive like habbib at the local kabab shop, smashing the gears around. Even with none of the above, dont expect to be lucky.
Stress and bad driving have broken more gearboxes then hp.
i know of 2 broken GTST boxes in all the cars ive known
one was a wierd anomoloy, the other was Rb26 in ER34 RWD
ive been driving mine pretty hard with basic power for 7 years and its fine
no mashed cogs, no blow up box, no broky etc
the stock box in the GTST i reckon is bulletproof
go ask a WRX owner what they think of the std box in the WRX
Sorry Ash the first part of my post was directed at xrotor, can see how you might have taken it directed at you given our quoting of power figures and statistics. Only reason I brought up GTR's is because of xrotor's post.
I've read it is the added stress of the transfer case on the output shaft responsible for the 3rd gear breakage in GTR boxes, but yes hard launches will do it in the lower gears. Rear wheel drive versions of a gearbox will always be stronger than all wheel drive (unless the all wheel drive has larger internals) because of less components and less things to turn. That is what I meant by the GTS-T box being stronger despite being similar.
thanks for the replies guys,
i knw that gear box's are strong i just dont wanna blow mine when am kicking it out here n there.
i got a mate with R34 who loves to kick it every where, now his gear box making all kinda of noises rattling, winding sound like a turbo lol.
i just dont want to have same problem, or is this normal when u thrash the gear box lol
It's normal when you thrash a gearbox for it to start making sounds after a while. Or any part of the car for that matter. There's a negative correlation between thrashing mechanical components and lifespan. Two options: drive it with care or fork out lots of dollars for more strength / replacement gearboxes :P
And yes Paul, WRX box = 2nd gear ripped off the mainshaft 90% of the time. Not cheap to fix them either!
or sounds like he loves to thrash it dumps / kicks the clutch every where lol
No, sounds like he does not know how to drive.
Simple as that.
Sorry mate but I've given my gearbox so much curry over 6 years and it's the same as it was the day i purchased it.
I've done over 100 passes with that gearbox, a good number of them with 370rwkw as well.
So you can imagine how easily my tyres turn on the street. I never miss a gear, clutch is always working 100% perfectly and i never change faster than the gearbox.
You mate does not know how to drive if it's making below 300rwkw and is failing.
Simple as that.
This is exactly what im talkin about birds, i had 300kw running low boost and bang! this time im going an OS set through a reputable business who know their shit, unlike some who knows everything about nothing.
Im pissed off with you more so that you charged 2k for a box outright and reco'ed my box that was f**ked!
You may one day do this to the wrong person :P
You have absolutely no idea what you are talking about, you make falsified claims, and that is why both Chasers and I told you where to go. For the record, even if you had standard power and a standard clutch and you came to me with a stripped gear I would still tell you where to go because it is NOT covered by warranty. No gearbox reconditioner, no matter how "reputable" will cover that damage under warranty. This is clearly explained on our invoice. If your mechanic, who purchased it from us, did not explain this to you clearly enough, then your issue is with him. If you have an issue with me, take it up with me outside of these forums using whatever avenues you would like to instead of trying to paint one side of a story here. End of discussion on the matter over these forums.
So the op is looking at 5K for the OS giken upgrade? I assume the alternative (PPG) is a similar price?
Sounds like it would be worth staying stock unless you know that you break standard gearboxes due to extreme power levels, and not poor driving technique :D
I am curious how much a standard + new sychro's rebuild is :banana:
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
