  • Replies 46
I thought there were two places, Kostecki's and Orbital...maybe not.
The idea of places that magically pass seemingly non compliant vehicles happens in the import community too...I'm sure.
Anywho I'm glad it's over...foolishness averted.
I spent a few dollars passing some paperwork ready for the IM240, $20.47 IIRC, I will definitely be writing to the transport authority requesting reimbursement. I doubt I'll succeed but ehh... I just wanna get up in their grill for being dickheads about the whole thing.
Its funny the dealings I had with KEC were nice and friendly, right up until I mentioned the car in question, then all I got was negativity and cvnts laughing at me. The jokes on them considering the outlay they must've spent for the equipment ($400,000+), that is now useless, not to mention the profit they won't be getting now hahahah
moooowaahahah!
Orbital weren't open to the public AFAIK.
This.
First I heard of the IM240 was when they rejected my first permit application (late 2007), called Kostecki about it & they said they were setting up for it but were still a few months away. Orbital was the only place set up for it, but weren't open to the public, just fleet cars & things like that. Probably nothing has changed since then
Char - which pits eventually passed your car? I have been wondering this myself if i can go to another pits after getting the report from one already which specifies having an IM240 done, didn't know if this was logged into some kind of system that will match the engine/chassis number..
read this link as you only need 5 gas now
http://www.transport.wa.gov.au/mediaFiles/...ht_Vehicles.pdf
Still have 5 Gas to pass but it is harder for the cammed V8's compared to the turbo cars.
LINK TO IM240 UPDATE.
The Government, through DoT, will continue to work with the motor trades industry to review the emission testing policy and ensure an outcome that is in the best interest of all stakeholders.
What the update link says is will continue to work with motor trades to review the emission policy, that does not mean its dead yet!
I heard MTA might support the IM 240 as long as the government run it.
I also heard cammed V8s are getting caned by the 5 gas as Drift says, and more cammed cars failed at idle cos of the 5 gas. than they would be under a drive cycle test.
Ring the DPI dont count our blessing yet.
so lame, makes me want to kill cute small fury animals , if i have to get a stock stagea exhaust i dont know what im going to do!!!!
This is the reason I kept all the stock parts that I have replaced with aftermarket ones in the garage just in case if I need them later on...
Although my parents are telling me to get rid of them as I'm turning the garge into a rubbish dump :whistling:
my list needed "all mods to have permits" i failed the pits 3 times.
the bloke kept telling me i needed im240 test to get permit for my exhaust it didnt actually say on the list 'im240 test'
i didnt get permits for anything haha..
id just reccomend not going to welshpool..ever!
Edited by Char
All inspections are stored on an electronic database, they know every inspection/ work order you have had. Thats why they started the TRELIS computer system up.
+1 for not going to Welshpool. Midland is awesome.
Been to Welshpool 15+ times
Always passed 2nd attempt never been asked to do emmisions thou
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
