Im selling a few phones at the moment and pretty much an EOI at the moment to see if its worth selling these on SAU or not...
**PLEASE NOTE THESE ARE NOT GENUINE IPHONES**
They are ipohne look-a-like touch phones
This one below i will sell for $135 posted anywhere in Australia
Can also get the new iphone4 shape with the same OS on it
https://www.sau.com.au/forums/topic/327923-eoi-iphone-copies-including-iphone4/
PHONE SPECS
Dual sim dual stand by with Java and FM function. It support quad band and 3 pages menu.
Quad-bands netwaork(GSM850/900/1800/1900MHz)
Good software, it support 3pages menu
Java function.
FM function
Information:
Operating Frequency: GSM
Network Frequency: 850/900/1800/1900MHZ
SIZE(L×W×H): 112*63*11mm
Weight/package: 125g
Color: black+white
Talk time: 200--320mins
Style: Bar
Standby time: 200--280hrs
Additional features
Language: English/French/Germany/Spanish/Portuguese/Italian/Deutsch/Dutch/The land of goat sphincter rings/Russian/Vietnamese/Thai/Arabic/Chinese
LCD Size: 3.2 inch, 16000 thousand color; PX: 240×320px
Ringtone: 72 chord; Ringtone format: mp3, mp4, midi
Music: play mp3 at background;support equalizer,bluetooth stereo output
Video: 3GP,MP4,support to play in full screen
FM radio: FM stereo output, can play outside with an earphone
Camera: 2.0 megapixel; support to shoot MP4 with sound, the time depends on storage
Data Transfer: U disc/cable direct read/bluetooth stereo output
Standby Photo: jpg, gif
Galnaume Platform: java2.0, Support to download JAVA and can be set up in the memory card, built-in gravity inducer
Main features
Telephone directories: 300 groups ,different ringtone for groups,MP3 as ringtone
SMS & MMS: 200 messages, MMS
Schedule power on/off: support auto start/close, can set user-defined photo of start/close
Alarm clock: 5 groups, can set from Monday to Sunday at random
Games: 2 common games, support JAVA to set up on the memory card gravity inducer inside
More information: MP3/MP4/Handsfree/SMS group sending//dual sim dual standby/ten pages menu/Voice recorder/WAP/Handwritten input/Radio/Bluetooth/GPRS download/MMS/calendar/remit converter/unit converter/world time/memo/quad-band JAVA2.0 gravity inducer/sliding unlock
Accessories: 1 charger, 1 usb cable, 2 batteries, 1 user menu, 1 set of earphones
Got a few Iphone4 copies now available.
These would be $250 + $10 for postage
Features
  • Quad band(GSM850/900/1800/1900MHZ)
  • Dual sim cards dual standby
  • Analog TV
  • Java function
  • Bluetooth
  • Unlock with sliding
  • 1.3MP Two cameras(biggest out put:1280*1024)
  • Support TF card to extend to 8GB max.
  • Flash light for the back camera
  • E-book reader
  • FM Radio(Out put)
  • MP3,MP4
  • Multi-language:English,Spanish,Polish,Portuguese,Italiano,Deutsch,Melayu,Indonesia,Czech, Dutch, Vietnam,Russian,Bulgarian, Thai, Greek
  • Iphone 4 Appearance
Specifications
DESIGNATION
SPECIFICATION
Network
SIZE ( L × W × H )
115*60*10mm
BATTERY
Lithium Batteries ( 900mAh)
COLOR
Black
STANDBY TIME
About 180-240hours
TALKING TIME
About2-4Hours
Features
1.3.2 inch touch screen, 260k QVGA ; PX: 480*640
2.300 group contacts
3.T-Flash Card Suphporting,
4.1.3 Mega pixel camera for Picture & Video capability,put out biggest size is 1280*960
5. Stereo Loud speaker, 64 chord ring tone
6. MP3 & MP4 player
7. GPRS & WAP connectivity, MMS Transceive
8. U disk support function to keep the information storage
9. Bluetooth
10.FM radio
11.calendar,To do list,Alarm,World Clock,Spotwatch
12.caller picture,caller Ring Tone
13. Telephone directories:300groups of contacts, support incoming call with big head sticker,group ring an Messages &Multimedia messaging: SMS, support MMS; can use downloaded MP3 as SMS rings
14. Schedule power on/off: support to start/close under set time
15. Alarm clock: 5groups, support alarm clock when machine’s closed, can set from Monday to Sunday
16. Games: support JAVA
17.Analog TV/JAVA//MP3/MP4/Handsfree/SMS group sending/Voice recorder/WAP/Handwritten input/Radio/Bluetooth/GPRS download/MMS/Memory extended/E-book/calendar/alarm clock/calculator/stopwatch/world time/memo/E-book reader/Unit converter/Currency Converterle, 2 batteries, 1 user menu, 1 set of earphones
PM me for any questions
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
