Hello there,
I am running R33 GTSTS2 with 14PSI of boost.
I am using the standard ECU, not retune has been done.
(But Nistune + Z32 ECU will be installed soon)
At current the car is making 300HP at the cluch.
However there is a bit of a strange behaviour.
Sometime when I floor it rapidly it feels as if the engine has been shut down for a few seconds.
It's quite violent, but no misfires or stuttering.
Then after a second or so the engine comes back to life and everything is back to normal (I have to ease off the pedal though)
In contrast when I floor the pedal a bit more sensitive everything is fine.
For example I can go to top speed with no problem whatsoever ..
Is this R&R?
https://www.sau.com.au/forums/topic/328005-is-it-rr/
Yep that sounds like R&R, 14psi is too much for the stock ecu and you will need a tuned/new ecu to fix that (or lower your boost right down)
Hi!
Thanks ..
Nistune Z32 ECU + AFM is here for the rescue.
I have no idea how R&R feels ... I thought it would be kinda smoother effect.
(It feels like the ECU is actually shutting down the whole engine for a moment)
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5334398
I'd be more worried about how long that standard turbo is gonna last at 14psi .. :wub:
(Sidenote - how do you know what power you have at the 'clutch'?)
Hi there,
I 'know' about the power because of the Dyno .. the 300 figures is obviously calculated.
(It's 250HP rear wheel)
Edited by Torques
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5334522
Ummm that is a chassis dyno, therefore it's "300hp" @ the rear wheels dude.
Although 300 is a bit dubious.
You can clearly see the big flattening off in the first graph, R&R mode kicking in. Plenty of results around that depict this.
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5334564
Hi!
Thanks for pointing this out ...
But it is definitely is not 300 rear wheel.
At the Dyno they first plotted the higher figure, I guess to impress customers.
Here's (attached) what they said it is RWHP
(I wish I had 300 at the rear)
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5334580
S_HP is predicted flywheel horsepower...
but thats ok because you have never been wrong
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5335006
I'm honestly stunned a tuner (and really, anyone who uses a dyno) would even bothering to use the 'predicted horsepower' feature given how inherently inaccurate it's going to be ... it's just going to confuse the owner, really. (But hey it gives a higher figure for the warm fuzzies, right?)
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5335036
Guess i should open the attachment fully next time to read the fine print, never to worry though when there are people like you are on hand!
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5335338
LOL,
This has really become a fun thread.
I like ->
'He is from England'
:whistling:
But ... I am half German, so only interested in real and precise numbers.
I don't know about the inherent formula to calculate 'clutch hp' but it can not be too far off from the truth.
Anyhow, I am aiming at HP 350+ at the rear and hope Nistune was a good investment to eventually get me there.
Cheers from the land of clutchpower,
Andrew
Here are some pictures from last weekend:
Jap Event
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5335857
Hello there,
Is this R&R?
It could be that you have reached the Air Flow limiter or "Boost cut", if that's the case its easy to sort out with nistune just open up your bin file and scroll down the bar on theft till you reach "TP Load Limit" set these to "255" or if your using the hex editer set them to "FF" this is maximum sume set it a lower so just above STD
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5335974
Thanks for pointing this out.
I will resolder/rewire the Z32ECU this weekend and dive into the abyss of Nistune :whistling:
I will definitely have questions!
https://www.sau.com.au/forums/topic/328005-is-it-rr/#findComment-5336051
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
    • And this is the the thing with a high powered, AWD, heavy car. The engine is easy, the driveline costs just as much as the engine. 🤷‍♂️ Welcome to GTRland. Whatever you think your budget is, double it. Whatever you think your timeline is, triple it.
    • I thought I'd heard rumor of someone that was developing a 6 speed kit to convert the 5 speed box. But maybe I was thinking of the PPG 6 speed sequential? That's about half the price of a car...
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
