Hey guys, I need some help from the experts here (hopefully I put this in the right area if not Mods please move).
I am trying to install my copy of NISSAN FAST on my new laptop but I can't get it to run. I have WIN7 Pro 64bit and the program seems to be having issues running. I can't setup the CD's. The actual software will load but when I try to open it it says no CD and when I try to run the cd setup part of FAST it throws a 64bit 32bit error of some sort.
I tried running in compatibility mode and that did nothing, ran as admin and re ran install as admin and none of this works. Will this work in 64bit Windows or not? I have searched here and on google for a while and the only info I found was a guy said it will run in compat mode on 64bit 7 by moving a file but he doesn't say which one.
I am thinking I will just dual boot XP or run it on my NIStune laptop but would really like to get it running on my new machine.
Any help from anyone running this on 7 64bit would be appreciated :wub:
https://www.sau.com.au/forums/topic/328023-nissan-fast/
Just use XPMode in Win7, It'll work then.
Not 64bit
Win 7 32bit is no probs.... no need for an XP Mode, just run it. As far as I know FAST is not compatible with 64bit OS's yet... well at least the 4 different versions I have tried.
https://www.sau.com.au/forums/topic/328023-nissan-fast/#findComment-5335018
Nope won't work. I found out today, Windows 7 64bit has got no support for 16bit apps (dropped it as of XP) and even though it is a 32bit app it still has a some legacy 16bit files or some BS. As a result of this it won't run in 64bit or in compatibility mode :whistling:
Looks like the only way to do this now is to run a virtual machine or just install it on my XP NIStune lappy. Unless someone actually has it running on 64bit. Oh well thanks for trying to help guys. Thread can prob be closed now :whistling:
https://www.sau.com.au/forums/topic/328023-nissan-fast/#findComment-5335986
Nope won't work. I found out today, Windows 7 64bit has got no support for 16bit apps (dropped it as of XP) and even though it is a 32bit app it still has a some legacy 16bit files or some BS. As a result of this it won't run in 64bit or in compatibility mode :D
Looks like the only way to do this now is to run a virtual machine or just install it on my XP NIStune lappy. Unless someone actually has it running on 64bit. Oh well thanks for trying to help guys. Thread can prob be closed now :cool:
Yeah i created a 32bit XP virtual machine so i could install FAST and its works perfectly there.
https://www.sau.com.au/forums/topic/328023-nissan-fast/#findComment-5336339
Thats what i mean.
I'm 95% certain 64bit Win7, just setup XPMode, which is a XP virtual machine within Win7, and off you go.
That is correct. Windows XPMode is 32 bit in Windows 7 in both 64 and 32 bit editions.
But if you are still having issues - run it completely in a virtual machine - it will also allow portability of the app - just copy the VM image.
https://www.sau.com.au/forums/topic/328023-nissan-fast/#findComment-5344367
At least that confirms what I was thought was right, and the whole purpose behind "XPMode" :whistling:
The image is only around 1.1 - 1.5gb as well if memory serves me correct.
So not big at all for what you get.
I'd say more towards 2GB because of Windows XP SP3 being integrated with it.
Still portable considering most USB sticks are 4GB+......
https://www.sau.com.au/forums/topic/328023-nissan-fast/#findComment-5346429
  • 1 month later...
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
