Ive been looking at up grading my oil pump from stock and always wondered about these billet pump gears
http://www.kec.com.au/index.php?option=com...&Itemid=327
they are around the $600 mark, has anyone used them, at what point would you consider the need to upgrade. would 350rwkw @ 8000 rpm in any RB engine
be safe with standard pump and shimed spring?
https://www.sau.com.au/forums/topic/328025-billet-oil-pmp-gears/
I came across these KEC gears not long ago but I had never heard of them (the gears, I know who KEC are) and am quite dubious.. I am more inclined to go with the JPC gears as JPC are reknowned for building tough RB30's whereas Kostecki's are reknowned for their big v8 work and ripping customers off (re: IM240 testing).
A friend of mine has the JPC gears on his 700hp 25/30. No dramas as yet.
That's very good to hear :laugh: got any more specs or details? how long has he had them? what does he rev the thing to?
Cheers!
Edited by bubba
The same engine had a N1 on there. Pulled is down due to a bearing failure and found to nice cracks in the gear.
The JPC ones are an upgrade but you can compare to the NITTO pumps.
You get what you pay for.
I thought the JPC gears were only for N1 oil pumps and not the standard ones?
p.s How would you remove the back plating of the oil pump when it has locktite on it?
impact screw driver or allen in the SR20 case.
We run new rotors in all our oil pumps (sr's) as thety are $80 from nissan.
As for rb26 i would track down whoever is making these as i cant image many places tooling up for it. Is TufRX3 (karl) doing them?
i cant see the point in buying billet gears... i would just buy a decent pump.
Had them a few months, revs to 8000rpm.
Nice
+1 for the impact screwdriver
I've already got an N1 pump and while there are no cracks, I can visually see wear on the drive surface and that worries me. I'm also not in a position to shell out another 1.5-2k for a new oil pump so if I can get some stronger gears for my N1 pump, then awesome. :)
I can see the point when i dont have a money tree, Hmmm $350 for gears that wont fail like stock ones,
or risk leaving stock ones in there. Easy choice for me when im on a budget.
depends, if the pump housing has to much rotor float you are up for a new housing and this gear set..... which is the same as wholesale on something decent. If you have a few housings that are in spec then yeah it makes sense.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
