Lots of interior plastics, trim pieces, a couple of back seats, door cards etc, air-con bits and pieces, boot trim, boot floor card etc. All offers considered on individual parts. Prefer pick-up in Shellharbour, NSW or can arrange pick-up weekdays at Silverwater, NSW.
Would like to make it easy for people to just come and collect these bits. Wife is freaking out that she can't move in the garage (telling her that, "that was the idea" didn't go down well. Not well at all.)
Air-con compressor, brackets etc
Air-con fan
Heat exchanger etc
Drilled and slotted rotors, used
Interior panels (rear), trimmed blue to match seats
Back seat trimmed in blue and black
Boot carpet (several)
Rubber from boot floor
Standard interior trim parts
Wood from boot floor
Air-con condensor
Rear firewall (boot) trim
Boot trim
R33 GT-R wing blade (white), random interior and boot plastics
Random plastic trim parts
Standard rear seat
More boot floor (with radical stickers :blink:)
Standard head gasket and exhaust manifold gasket from VRS kit
  • 2 months later...
  • 4 months later...
  • 3 months later...
  • 1 month later...
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
