my 25/30 is starting to be built this weekend. only part ive havnt yet got lined up is pistons. have read through so many pages on the forum and cant find a simply straight up answer. i need a decent comp ratio... obviously above 8.3 or thereabouts. will CP flat top pistons to suit RB30 give me a decent ratio. need a straight answer asap. what piston have ppl used to get decent comp ratio?
https://www.sau.com.au/forums/topic/328764-which-pistons/
CP
All compression ratios are based on zero deck height
1.2mm head gasket (7.13cc)
RB25 @ 62.5cc
RB26 @ 64.5cc
They assure me they have done alot of work to make sure the facts are correct.
p/n= CP-RB30/26-.20
Flat top with no valve pockets
8.2:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize but can be custom ordered in any size.
p/n= CP-RB30/26-.20-9.0
6.0cc dome top,
9.0:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
*Care must be taken when using on RB26 with more than 11.5mm valve lift*
ARIAS
Suit RB30/26
p/n= AP332103
flat top
21mm pin
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 8.4-8.6
Suit RB30/26
p/n= AP332104
10.6cc dome top
21mm pin
COMPRESSION RATIO 9.2-9.4
Suit RB30/25
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
WISECO
Skyline RB30 w/ DOHC RB25det cylinder head
1.260" compresion height, 66.5cc head chamber, Dish top -11.3cc, 7.0:1 compression ratio, 21mm pin, 1mm gasket thickness, 1mm deck clearance.
K577M865 86.5mm
K577M87 87.00mm
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5344658
Thanks guys. Especially titan. Extreamly helpful. Now know exactly what pistons will give me what comp ratios. As car is being built for circuit use, response is important, so a comp ratio of 9:1 would be excellent. Arias dome tops it is. 9.2 - 9.4 pending they in stock other wise dome top CP's
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5345149
I've got the Wisecos (was originally built before all the others came out, I think they're pretty much 30ET pistons), still got plenty of off boost torque even with the 7:1 CR, we'll see what it does with the new turbo.. I imagine I'll be able to safely run heaps of boost and timing!
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5345384
had a play around with some figures today and the 10.6cc dome top arias and the 6cc dome top CP both seem that they will get me where i need to be. The 13cc dome top arias will obviously give me a fairly high comp ratio and in turn will hinder the amount of boost i can wind into it. Im planning on running about 17 psi through a gt3582 at this stage.
The flat top pistons all seem to ofter a dramatically low CR and im not planning on throwing response out the window lol.
On a seperate note, i began removal of gearbox from the 33 this arvo. Clutch slave off... Tail shaft bolts off... So i started to remove bolts from block to box and got stuck on that annoying little f**ker right up the top. Any tips or suggestions or am i pulling the head off tomorrow???? Lol
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5346391
I imagined it would of been a dog of a thing down low with that CR
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5346412
Lots of really long extensions... like a few feet worth.. that's how I get to the top bellhousing bolts on mine.
Nope, not as bad as you'd think. Small turbo and stock runners, so we'll see what it's like with the bigger turbo and a forward facing plenum once it's back together. I imagine if I was to run really big cams then it would probably be quite noticable but I'm only running stockers.
Edited by bubba
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5346489
I have a metre long extension for that annoying bolt. works a treat.
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5346498
lol gearbox out... what a pain. would not wish that upon my enemies; as im very impatient i took to the stick with an angle grinder...
now i can rip the fly wheel out so i can get it balanced up with my rb30 crank and balancer
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5348499
Yeh weve learnt over the last 5 years of in/outs its just easier to disconnect everything and just take motor/gbox out in one hit. Do what you need to do, then chuck it back in!
Comment about your piston choice mate. Your going for higher comps to help response? Weve run both cp's flat top and domes and its makes bugger all difference. What does make the difference is manifold choices. Or so we found when at the track.
On a road car running 9:1 might be well and good, but for 95% of the time whilst on the race track you never fall off boost so much that you would really need that extra comp to help get you back on. Whilst racing you more then likely wont notice the difference. I couldnt.
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5349081
Yeh weve learnt over the last 5 years of in/outs its just easier to disconnect everything and just take motor/gbox out in one hit. Do what you need to do, then chuck it back in! Comment about your piston choice mate. Your going for higher comps to help response? Weve run both cp's flat top and domes and its makes bugger all difference. What does make the difference is manifold choices. Or so we found when at the track. On a road car running 9:1 might be well and good, but for 95% of the time whilst on the race track you never fall off boost so much that you would really need that extra comp to help get you back on. Whilst racing you more then likely wont notice the difference. I couldnt.
point taken. i have done a lot of research and talking to people over past week including people who have rb30det with lower CR and i feel that staying close to the 9:1 ratio will suit my application. i guess time will soon tell. so you have played around with a few different exhaust manifolds to get the correct result?
https://www.sau.com.au/forums/topic/328764-which-pistons/#findComment-5350252
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
