  • Replies 329
Posted Images
Hey Michael, yes there definately will be sign up forms there on the day! Alternatively, you are more than welcome to use our brand new online application form!
http://japan2011test.downsouthlan.net/inde...t&Itemid=27
Done,
submitted form!
Cheers
I've just made the bank transfer of $35 for the dyno day. Description for the transaction is "typevu dyno day"
Cool. I'll keep an eye out for it.
Brezza, I have your form. Just awaiting confirmation of payment. :D
Hey Ruby,
did my payment clear?
Brezza, membership payment and dyno day payment confirmed.
Volk34, dyno day payment confirmed.
Aberax, dyno day payment confirmed.
Matty T, dyno day payment confirmed.
Type Vu, dyno day payment confirmed.
