Ok folks, I have an r33 gts-t.
Current exhaust mods are:
- Bellmouth 3inch dump/front pipe
- Xforce 3 inch cat (apparently, came with car)
- 3 inch stainless mandral bent system which also came with car. (it is jasma approved, so its quiet, one huge muffler at the rear that goes 3inch in then splits into two pipes inside and then back out with a single 3inch again, middle muffler is same brand but smaller about the size of a shoe box)
the mufflers appear so say K&H on them, never heard of them?
The car flows great, good performance, cant complain but its too quiet!
It literally makes almost no noise. It is completely drained out by the induction noise.
RB25s have a good note and I would like to get some of that without being too loud and offensive obviously.
Recommendations for a good sensible note? remove rear muffler for a cannon? different rear muffler, no rear muffler etc?
thanks
https://www.sau.com.au/forums/topic/328870-exhaust-modification/
i would but its all welded, beautiful system. It was a novelty to have it that quiet but truly it makes no noise, no different to stock system. I was thinking have the rear muffler changed to the flange (half way between middle and rear muffler) so I can change back if needed?
Not looking for police attention just a nice, crisp but still reasonably quiet exhaust note
Edited by TUF250
i have a jasma fujutsubu canon and just a hotdog in my 3.5inch system, and its as loud as it can get before going over the allowed db, im getting a 3 inch bellmouth and highflow cat (i have stock dump/front and cat) so it will louden it up a bit! cos im after a bit more noise to, so to answer your question, since u have a similar system to mine, i think taking out the center muffler and get a hotdog (if you dont already have one) should make it sound nice.
Just get the centre muffler cut out and a straight piece welded in.
Ok sounds good. Would be cheapish too. What about this rear muffler, would it be restrictive? the 3inch in 3inch out but with the twin pipes running through it? its a huge muffler. ill try get a pic. doing the centre would be cheaper than the rear (less bends) Also I could keep my current tip which I dont mind
check out my for sale thread (in sig) for my old exhaust. unique and mildly sounding. :D enough of the sales pitch.
i got a custom 3 inch made up with a straight through muffler and thats it. same sort of sound from my old one just deeper and louder. when it opens up ~4500+ it really starts to roar. i frukin love it... my petrol seems to be draining somewhere.... ;)
Edited by SLY-25T
run a decat, will be slightly louder and slightly faster, best of both worlds!
pros.
more power
more response
louder
their cheap, sell ur current high flow cat and ur infront!
ur system sounds like a quality system, this way u dont have to modify it and f**k with anything
cons.
the environment (f**k the environment)
Edited by jimmys-33T
has anyone got a 3 inch system with a high flow cat and only one big muffler, what did you think if so?
3 inch dump pipe high flow cat and lukey turbo muffler 3in 3 out. no police attention but loud enough and seems to flow enough
pros.
more power
more response
louder
cons.
CONS! the $$$$$$$$$$ Worth of Ass Raping you will receive if you get caught.
yeah wont be getting a de-cat.
I wonder if just removing the centre muffler and replacing with a straight pipe would sound good? The rear muffler looks quite big and has a twin chamber type design. K&H brand. Might be a good way to go, wont cost much either i figure. thoughts?
im in vic nismoid. I wonder if just removing the centre muffler and replacing with a straight pipe would sound good? The rear muffler looks quite big and has a twin chamber type design. K&H brand. Might be a good way to go, wont cost much either i figure. thoughts?
IMO then you are very silly to change it.
If it's quiet now, then its probably only just legal.
Changing it wil mean you are then over the dB limit almost certainly - I'm yet to see a single muffler system pass.
So you'll end up having to change back for EPA defect reasons anyway.
Stealth & silent is the new black in Vic, it's sadly the only way you can enjoy a Import with relatively low hassle.
Having it loud just simply is not worth the heartache, anyone who's battled the EPA for years (like myself), would most likely agree.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
